1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Getting started talking to a device
To: "Leblanc, Gregory" <[email protected]>
Date: Thu, 12 Aug 2021 20:23:36 +0000
Hi Greg,
Your st.cmd.brief file is not really correct.  You have these commands after iocInit.
  1.
drvAsynIPPortConfigure("watlow1", "10.0.0.196:502", 0, 0, 0)
  2.
modbusInterposeConfig("watlow1", 0, 2000, 0)
  3.
drvModbusAsynConfigure("watlow.w.1", "watlow1", 0, 16, -1, 4, 0, 2000, "watlow1");
  4.  ...
Those should all be before iocInit.
From: Tech-talk <[email protected]> on behalf of Leblanc, Gregory via Tech-talk <[email protected]>
Sent: Thursday, August 12, 2021 3:16 PM
To: [email protected]
Subject: RE: Getting started talking to a device
Woot!  Making some real progress now!  I can now execute iocBoot/iocCsHeater/st.cmd without any errors, although I appear to have added so much documentation that it is quite noisy.  A bit of sed work shortens that up nicely, so that I can see what’s going on, and I’ll put that all into github shortly.
https://pastebin.com/YmEwjY7S
I’m guessing that the next thing I’ll need is to take
https://github.com/tauferg/Watlow-PM/blob/master/Watlow_PM862FJ-3LEJAA_Module/watlowApp/Db/Watlow_PM_Analog_Input.template
from Gary’s work and beat it into a .db file for myself.  I think I’ll probably work on reading just the first analog input, before I think about doing anything else.
I’ll probably create a new pull request against Watlow-PM to replace the numeric data types with slightly more readable strings as well.
     Greg
From: Tech-talk <[email protected]> On Behalf Of Paduan Donadio, Marcio via Tech-talk
Sent: Tuesday, August 10, 2021 4:56 PM
To: EPICS Tech Talk <[email protected]>
Greg,
I see that you’ve already fixed what Mark Rivers pointed out. Are you still having problems to build the application?
I don’t know if it will do any difference, but usually the module path comes before EPICS base in the configure/RELEASE file. Place it below “Variables and paths to dependent modules:”.
Just to make things more organized, you could separate a block for DBDs from a block for LIBS in your src/Makefile. For example, place CsHeater_LIBS += asyn below “Add all the support libraries needed by this IOC”.
I think the next challenge will be to run the IOC. Let us know if you hit another wall.
My best,
Márcio
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of EPICS tech-talk <[email protected]<mailto:[email protected]>>
Reply-To: Mark Rivers <[email protected]<mailto:[email protected]>>
Date: Tuesday, August 10, 2021 at 10:34 AM
To: "'Leblanc, Gregory'" <[email protected]<mailto:[email protected]>>
Cc: EPICS tech-talk <[email protected]<mailto:[email protected]>>
You should delete the last line in CsHeaterApp/src/Makefile
$(COMMON_DIR)/CsHeater.dbd: $(COMMON_DIR)/asyn
From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of Leblanc, Gregory via Tech-talk
Sent: Tuesday, August 10, 2021 10:01 AM
To: [email protected]<mailto:[email protected]>
I put the code into github at the URL below.  I did find one place where I had
CsHeater_DBD += asyn
But it should have been
Latest output from make is at : https://pastebin.com/5Ft4z6jn<https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpastebin.com%2F5Ft4z6jn&data=04%7C01%7Cleblanc%40ohio.edu%7Ca7fec19849144e8812d308d95c414106%7Cf3308007477c4a70888934611817c55a%7C0%7C0%7C637642257612052310%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=vTOYFdN0f0mIInLTSqiLHEWR6kYarL1DQf80gA%2FC2IM%3D&reserved=0>
https://github.com/gregoryleblanc/CsHeater<https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fgregoryleblanc%2FCsHeater&data=04%7C01%7Cleblanc%40ohio.edu%7Ca7fec19849144e8812d308d95c414106%7Cf3308007477c4a70888934611817c55a%7C0%7C0%7C637642257612052310%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=rzMKCzIM5zEJF4%2F%2BzEhAnsI2T0dtMwBjLaX8zPfWP4Y%3D&reserved=0>
     Greg
From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of Paduan Donadio, Marcio via Tech-talk
Sent: Monday, August 9, 2021 10:44 PM
To: EPICS Tech Talk <[email protected]<mailto:[email protected]>>
Greg,
if you don’t have the code in GitHub, could you attach your configure/RELEASE and csHeaterApp/src/Makefile?
My best,
Márcio
Date: Monday, August 9, 2021 at 3:35 PM
This is your error:
perl -CSD /home/pi/EPICS/epics-base/bin/linux-arm/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/pi/EPICS/epics-base/dbd -I/home/pi/EPICS/support/asyn/dbd -o CsHeater.dbd base.dbd asyn.dbd drvAsynIPPort.dbd asyn
It is the final “asyn” that is wrong.  I don’t know what it causing it, but I think it must be a mistake in your application Makefile.  Is your code on Github or somewhere else we can see it?
Sent: Monday, August 9, 2021 4:25 PM
Marcio,
Thanks, that’s gotten me a lot further than I was last week!
I’ve gotten far enough to try to build my application.  When I run make, I get the output at:
https://pastebin.com/esyPHRC4<https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpastebin.com%2FesyPHRC4&data=04%7C01%7Cleblanc%40ohio.edu%7Ca7fec19849144e8812d308d95c414106%7Cf3308007477c4a70888934611817c55a%7C0%7C0%7C637642257612052310%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=lk%2Fenw6045K71rcBAW5cu0AW1%2BKBRUfwFz69t%2FT4s6M%3D&reserved=0>
Based on that, I added “$(COMMON_DIR)/CsHeater.dbd: $(COMMON_DIR)/asyn” to my Makefile under the line that says “#  ADD RULES AFTER THIS LINE” which changes the make output to this:
https://pastebin.com/ZaftdjaN<https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpastebin.com%2FZaftdjaN&data=04%7C01%7Cleblanc%40ohio.edu%7Ca7fec19849144e8812d308d95c414106%7Cf3308007477c4a70888934611817c55a%7C0%7C0%7C637642257612062274%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=TkAIe4yNxG2hMgMr3LubZhE7NOmYaQcAaub3oroMnNk%3D&reserved=0>
This feels like I have some path incorrect or incomplete, but I haven’t stumbled across it yet.
As a summary, I have:
epics_base installed to /home/pi/EPICS/epics-base
asyn installed to /home/pi/EPICS/support/asyn
StreamDevice installed to /home/pi/EPICS/support/StreamDevice
And I am working to create CsHeater in /home/pi/EPICS/CsHeater
     Greg
Sent: Friday, August 6, 2021 11:16 PM
Hello, Greg.
All you have is the git repo that you've mentioned?
To build an IOC you will need a configure directory, with configure/RELEASE (or configure/RELEASE.local) pointing to the needed modules, like Asyn. You will also need a Makefile on your IOC application root directory. The st.cmd file usually goes inside an iocBoot/<ioc_name> directory.
My recommendation: assuming that you have EPICS base installed, create a new directory where you want to place your IOC application and, inside it, start a new IOC application directory structure using
makeBaseApp.pl -t ioc <name_of_your_ioc_application>
Then copy the contents of the Watlow-PM/Watlow_PM862FJ-3LEJAA_Module/watlowApp/Db/ directory to <name_of_your_ioc_application>App/Db.
Next, change your configure/RELEASE file, by adding the path to where you've installed Asyn. You must add to the <name_of_your_ioc_application>App/src/Makefile, the Asyn library and dbds:
<your_application>_DBD += asyn.dbd
<your_application>_DBD += drvAsynIPPort.dbd
<your_application>_LIBS += asyn
The DBDs provides you with the functions used in the IOC shell, like drvAsynIPPortConfigure.
See if issuing make brings a successful build.
Still inside the IOC application top directory use
makeBaseApp.pl -i -t ioc <name_of_your_ioc>
This will create an iocBoot/<name_of_your_ioc> directory. Overwrite the st.cmd file with "st.cmd.ModbusAddresses Only" and rename it back to st.cmd.
This st.cmd from the repo only initializes the driver but doesn't load the databases. Without loading the databases, you will have no PV to read/write in the network.
I hope that the IOC application maintainer can contact you to describe which databases to load for your case. I know nothing about the Watlow controller and couldn't help with this.
HTH.
[cid:[email protected]]
Márcio Paduan Donadio | Control Systems Engineer
Advanced Control Systems Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.5007 | w: slac.stanford.edu<https://slac.stanford.edu>
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Leblanc, Gregory via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Friday, August 6, 2021 1:27 PM
To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>>
Subject: Getting started talking to a device
Hi folks,
I’m still poking around at this whole EPICS thing, attempting to get my feet wet.  I thought that I might try to talk to a temp controller I have on our Cs Sputter source here.  Currently we only adjust the setpoint by walking into the vault and using Bluetooth on our phones.  The controller is an EZ-ZONE model number PM6C1CA-GAAAAAA.  We have an ethernet module for it, and it’s picked up an address from DHCP, which I can ping from the Raspberry Pi where I’ve installed EPICS Base.
I found the pieces that Gary published at https://github.com/tauferg/Watlow-PM<https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Ftauferg%2FWatlow-PM&data=04%7C01%7Cleblanc%40ohio.edu%7Ca7fec19849144e8812d308d95c414106%7Cf3308007477c4a70888934611817c55a%7C0%7C0%7C637642257612062274%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=kxokDkFqEJSRQ6136R8Ncz7JUqqNJ9dJ4TW5dzE09HM%3D&reserved=0> though I can’t find the controller mentioned on the Watlow website.  I cloned via git and determined that the second parameter to drvAsynIPPortConfigure should be the ip address.  From Watlow_PM862FJ-3LEJAA_IOC/st.cmd.ModbusAddresses\ Only I have:
drvAsynIPPortConfigure("watlow1", "10.0.0.196", 0, 0, 0)
The next step, per README.md is to “Rename the files and place in the appropriate directories.”  Which files need to be renamed, and where do they need to be placed?  What is the next step here, or do I need to back up and continue working on the st.cmd file?  Any pointers appreciated.
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701
M: (401) 52-OUAL1 or (401) 526-8251
JPEG image
RE: Getting started talking to a device Leblanc, Gregory via Tech-talk
Re: Getting started talking to a device Paduan Donadio, Marcio via Tech-talk
RE: Getting started talking to a device Mark Rivers via Tech-talk
Prev: RE: Getting started talking to a device Leblanc, Gregory via Tech-talk
Next: RE: Getting started talking to a device Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
