1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: IOC up, but can't connect via channel access
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 13 Aug 2021 15:48:00 +0000
Hi Tech Talk,
I have just restarted a set of IOCs after puppetizing their configuration. They are accessible via a Telnet ProcServ connection, and dbpf shows everything populated and defined. However, if I try to use caget, caput, etc. there is no connection. What are the possible causes of this? EPICS_CA_AUTO_ADDR_LIST seems to be set as “YES” and other IOCs I haven’t touched are still reachable.
Evan
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: [email protected]
cid:image002.jpg@01D07041.57B6D750
Re: IOC up, but can't connect via channel access Johnson, Andrew N. via Tech-talk
Prev: IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
Next: Re: IOC up, but can't connect via channel access Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
