1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: IOC up, but can't connect via channel access
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Daykin, Evan" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 13 Aug 2021 16:22:06 +0000
Hi Evan,
On Aug 13, 2021, at 10:48 AM, Daykin, Evan via Tech-talk <[email protected]> wrote:
I have just restarted a set of IOCs after puppetizing their configuration. They are accessible via a Telnet ProcServ connection, and dbpf shows everything populated and defined. However, if I try to use caget, caput, etc. there is no connection. What are the possible causes of this? EPICS_CA_AUTO_ADDR_LIST seems to be set as “YES” and other IOCs I haven’t touched are still reachable.
Is Puppet running them inside a container? If so you need to configure that to share the host’s network (or run a CA Gateway between the host’s network and the internal container network, but I don’t really recommend doing that).
The iocsh command ‘casr 1’ will show you what the network interfaces are that the CA server is listening on and sending beacons to.
- Andreww
Complexity comes for free, simplicity you have to work for.
IOC up, but can't connect via channel access Daykin, Evan via Tech-talk
Prev: IOC up, but can't connect via channel access Daykin, Evan via Tech-talk
Next: Re: IOC up, but can't connect via channel access Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
