1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: ADCameralink on Linux
From: Дмитрий Прощенко via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 16 Aug 2021 15:41:01 +0300
Hi all!
I want to integrate pco.edge and Camera Link HS in EPICS for Linux. Is it possible to do it using areaDetector? I used the Installation guide, bit had a build error related to ADCameralink. I was able to find a Silicon Software drivers (siso-5.7.0), but I do not understand how to use drivers in the project. Should I replace siliconSoftwareSupport with siso-5.7.0 and rewrite Makefile?
Best regards!
Re: ADCameralink on Linux Mark Rivers via Tech-talk
Prev: RE: IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
Next: Re: IOC PVA on mTCA CPU requires environment variables to be set Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: RE: IOC up, but can't connect via channel access Daykin, Evan via Tech-talk
Next: Re: ADCameralink on Linux Mark Rivers via Tech-talk
ANJ, 16 Aug 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
