1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: ADCameralink on Linux
To: Дмитрий Прощенко <[email protected]>
Date: Mon, 16 Aug 2021 15:13:33 +0000
Most people using PCI cameras are using Window and ADPcoWin. ADCameraLink is less well used and tested, but it should work on Linux. If you get it working please make a pull request so others can benefit from your work.
Sent from my iPhone
> On Aug 16, 2021, at 7:41 AM, Дмитрий Прощенко via Tech-talk <[email protected]> wrote:
> Hi all!
> I want to integrate pco.edge and Camera Link HS in EPICS for Linux. Is it possible to do it using areaDetector? I used the Installation guide, bit had a build error related to ADCameralink. I was able to find a Silicon Software drivers (siso-5.7.0), but I do not understand how to use drivers in the project. Should I replace siliconSoftwareSupport with siso-5.7.0 and rewrite Makefile?
> Best regards!
ADCameralink on Linux Дмитрий Прощенко via Tech-talk
Prev: Re: IOC PVA on mTCA CPU requires environment variables to be set Michael Davidsaver via Tech-talk
Next: Question about retrieve history data in archiver appliance lzfneu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: ADCameralink on Linux Дмитрий Прощенко via Tech-talk
