1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: LIB_LIBS getting ignored
From: "Jones, Edward \(CODAS&IT\) via Tech-talk" <[email protected]>
Date: Tue, 24 Aug 2021 12:24:36 +0000
Hello,
I’m trying to run a build where we’ve set INSTALL_LOCATION to /prefix and have found a buildable form with:
make EPICS_BASE=/prefix SUPPORT=/prefix
However, when I try to build my IOC itself at the final hurdle it doesn’t seem to link anything. This is what it tries to link:
/usr/bin/x86_64-w64-mingw32-g++ -o PICamApp.exe -static -L/ADPICam/lib/windows-x64-mingw -L/ADPICam/iocs/PICamIOC/lib/windows-x64-mingw       -m64    -static-libgcc -static-libstdc++         PICamApp_registerRecordDeviceDriver.o PICamAppMain.o    -lADPICam -lPicam  -lnetapi32    -lpsapi -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm -ldbghelp
Which lacks all the EPICS_BASE_IOC_LIBS, when I manually navigate to that directory and link it like so:
/usr/bin/x86_64-w64-mingw32-g++ -o PICamApp.exe -static -L/ADPICam/lib/windows-x64-mingw -L/ADPICam/iocs/PICamIOC/lib/windows-x64-mingw -L/prefix/lib/windows-x64-mingw      -m64    -static-libgcc -static-libstdc++         PICamApp_registerRecordDeviceDriver.o PICamAppMain.o    -lADPICam -lPicam  -lnetapi32    -lpsapi -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm -ldbghelp -ldbRecStd -ldbCore -lca -lCom -lasyn -lADBase -lca -lCom -lxml2 -lgdi32 -loleaut32 -lwsock32 -lws2_32 -lpsapi -ldbghelp -lversion -lzlib -lpv -ladvapi32 -luser32
This works. So it looks like the build method is missing all LIB_LIBS definitions. Could someone help to understand this? If you need I can share our work but must be privately done.
Ed
Re: LIB_LIBS getting ignored Johnson, Andrew N. via Tech-talk
Prev: Re: AD Stats with URL camera Profile problem Mark Rivers via Tech-talk
Next: EPICS support for Keithley 6517A unavailable, does anyone have it? Adam Szwandziak - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: LIB_LIBS getting ignored Johnson, Andrew N. via Tech-talk
