1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: LIB_LIBS getting ignored
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Jones, Edward (CODAS&IT)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 24 Aug 2021 17:13:04 +0000
Hi Ed,
On Aug 24, 2021, at 7:24 AM, Jones, Edward (CODAS&IT) via Tech-talk <[email protected]> wrote:
I’m trying to run a build where we’ve set INSTALL_LOCATION to /prefix and have found a buildable form with:
make EPICS_BASE=/prefix SUPPORT=/prefix
Your setting EPICS_BASE (and possibly SUPPORT too) on the make command-line is likely to be (at least part of) the reason for your issue. You really do have to set all paths in a configure/RELEASE file or in a RELEASE.local file that gets included from that because the build system has Perl scripts which read the RELEASE files independently of GNUmake and use the results to provide things to the build system like the list of paths to be searched for header and library files. I haven’t looked at the build in detail to see why you might be getting that problem, but please start by adding EPICS_BASE and SUPPORT to your RELEASE file chain and report back to tech-talk if that doesn’t (help you) solve it.
However, when I try to build my IOC itself at the final hurdle it doesn’t seem to link anything. This is what it tries to link:
/usr/bin/x86_64-w64-mingw32-g++ -o PICamApp.exe -static -L/ADPICam/lib/windows-x64-mingw -L/ADPICam/iocs/PICamIOC/lib/windows-x64-mingw       -m64    -static-libgcc -static-libstdc++         PICamApp_registerRecordDeviceDriver.o PICamAppMain.o    -lADPICam -lPicam  -lnetapi32    -lpsapi -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm -ldbghelp
Which lacks all the EPICS_BASE_IOC_LIBS, when I manually navigate to that directory and link it like so:
/usr/bin/x86_64-w64-mingw32-g++ -o PICamApp.exe -static -L/ADPICam/lib/windows-x64-mingw -L/ADPICam/iocs/PICamIOC/lib/windows-x64-mingw -L/prefix/lib/windows-x64-mingw      -m64    -static-libgcc -static-libstdc++         PICamApp_registerRecordDeviceDriver.o PICamAppMain.o    -lADPICam -lPicam  -lnetapi32    -lpsapi -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm -ldbghelp -ldbRecStd -ldbCore -lca -lCom -lasyn -lADBase -lca -lCom -lxml2 -lgdi32 -loleaut32 -lwsock32 -lws2_32 -lpsapi -ldbghelp -lversion -lzlib -lpv -ladvapi32 -luser32
This works. So it looks like the build method is missing all LIB_LIBS definitions. Could someone help to understand this? If you need I can share our work but must be privately done.
I’m the lead maintainer for the build system but I don’t have time to look into any details this week. I’m pretty sure the above should solve it, but if not you might also get some input from others too as long as you respond back to the list and not just to me privately. It often helps to post parts of your Makefiles if they’re your own or you have made changes to them, or pointers to online copies if they are unmodified from published support modules. We shouldn’t have to see any private code to help fix this.
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: LIB_LIBS getting ignored Jones, Edward (CODAS&IT) via Tech-talk
Prev: RE: Trouble with macro substitutions Leblanc, Gregory via Tech-talk
Next: Watlow_PM communication Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: LIB_LIBS getting ignored Jones, Edward (CODAS&IT) via Tech-talk
Next: RE: LIB_LIBS getting ignored Jones, Edward (CODAS&IT) via Tech-talk
