1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: aravisGigE: no device found
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Hasan SANSAR <[email protected]>
Cc: [email protected]
Date: Wed, 25 Aug 2021 13:17:11 -0700
On 8/25/21 12:19 PM, Hasan SANSAR via Tech-talk wrote:
> Hi all,
> I built aravisGigE R3-0 with areaDetector R3-3-1 and EPICS 3.15.8 on CentOS 7.9 on VirtualBox. I think there is no problem on building of EPICS, areaDetector and aravisGigE, because the driver was built.
> The other properties of my environment: asynDriver from GitHub, sequencer 2.2.9, autosave 5.7.1, busy 1.6.1, sscan 2.10, calc 3.6.1, ipac 2.7, iocStats on GitHub, ADCore R3-3-1, ADViewers R1-1, ADSupport R1-4.
> When I try to get informations from Baumer VLG-20M CCD camera with arv-tool-0.6, I'm getting warning "no device found". But, the commercial software of camera is running on my host machine(Linux Mint 21.04).
> And I can get ping from camera IP, but telnet command timed out.
> How can I solve this problem? Should I change environment I use? Or else, could it just be a network problem caused by a camera or CentOS 7.9?
It would help us to know if the 'arv-tool' CLI utility lists your camera.
cf. http://manpages.ubuntu.com/manpages/focal/en/man1/arv-tool-0.6.1.html
If it doesn't, I would suspect a network problem.  Last I checked aravis
only did discovery by UDP broadcast, while some other clients have the
option for only UDP unicast.  This was some years ago, so aravis might
be able to connect by IP address now.
Things to try.  Check that both camera and computer have the same broadcast
address (and are on the same network segment).  Check for firewall rules
effecting broadcasts.
fyi. Wireshark can decode some GVCP protocol messages.
aravisGigE: no device found Hasan SANSAR via Tech-talk
Prev: aravisGigE: no device found Hasan SANSAR via Tech-talk
Next: EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: aravisGigE: no device found Mark Rivers via Tech-talk
