1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: aravisGigE: no device found
To: Hasan SANSAR <[email protected]>
Date: Thu, 26 Aug 2021 00:23:38 +0000
You need to get arv-tool to work before aravisGigE or ADAravis will work.
> And I can get ping from camera IP, but telnet command timed out
telnet is not expected to work to a camera. What port are you trying to telnet to?
Try disabling any firewall.
Sent from my iPhone
> On Aug 25, 2021, at 3:19 PM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
> Hi all,
> I built aravisGigE R3-0 with areaDetector R3-3-1 and EPICS 3.15.8 on CentOS 7.9 on VirtualBox. I think there is no problem on building of EPICS, areaDetector and aravisGigE, because the driver was built.
> The other properties of my environment: asynDriver from GitHub, sequencer 2.2.9, autosave 5.7.1, busy 1.6.1, sscan 2.10, calc 3.6.1, ipac 2.7, iocStats on GitHub, ADCore R3-3-1, ADViewers R1-1, ADSupport R1-4.
> When I try to get informations from Baumer VLG-20M CCD camera with arv-tool-0.6, I'm getting warning "no device found". But, the commercial software of camera is running on my host machine(Linux Mint 21.04).
> And I can get ping from camera IP, but telnet command timed out.
> How can I solve this problem? Should I change environment I use? Or else, could it just be a network problem caused by a camera or CentOS 7.9?
> Hasan Sansar
aravisGigE: no device found Hasan SANSAR via Tech-talk
Prev: EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
Next: Re: EPICS sequencer web page redirect problems Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: aravisGigE: no device found Michael Davidsaver via Tech-talk
Next: EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
