1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: subArray behavior reading just 1 element
From: Lucas Russo via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 1 Sep 2021 19:02:37 -0300
Hi Andrew,
Ok. I will try that.
Thanks!
On Wed, Sep 1, 2021 at 6:43 PM Johnson, Andrew N. <[email protected]> wrote:
Hi Lucas,
On Sep 1, 2021, at 4:16 PM, Lucas Russo <[email protected]> wrote:
lerwys@lerwysPC:~$ caget wave
wave 5 1 2 3 4 5
lerwys@lerwysPC:~$ caget subarr
subarr 5 2 0 0 0 0
subarr always returns an array of 5 elements, but I was trying to achieve a subArray of only 1 element. Something like:
subarr                         2
Is that possible?
Try using caget -c subarr instead — unfortunately caget without a -c option will always print the maximum number of elements that the array can hold (zero-filled after the number received), but using -c it uses a CA get_callback() API which asks the IOC how many elements the array currently holds and shows that instead. That will be 1 so you should get what you’re asking for.
- Andrew
Complexity comes for free, simplicity you have to work for.
subArray behavior reading just 1 element Lucas Russo via Tech-talk
Re: subArray behavior reading just 1 element Lucas Russo via Tech-talk
Re: subArray behavior reading just 1 element Johnson, Andrew N. via Tech-talk
Prev: Re: subArray behavior reading just 1 element Johnson, Andrew N. via Tech-talk
Next: Quickstart archiver appliance error frangil.ramirez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
