1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Quickstart archiver appliance error
From: "frangil.ramirez via Tech-talk" <[email protected]>
To: [email protected]
Date: Fri, 03 Sep 2021 15:59:48 +0300
I am trying to get the quickstart runing but I got this error (see below) and I haven't been able to solve. I checked another post with similar error but I don't see the solution.
Using CATALINA_OPTS:
Sep 03, 2021 3:28:49 PM org.apache.catalina.startup.Catalina stopServer
SEVERE: Could not contact [localhost:8005] (base port [8005] and offset [0]). Tomcat may not be running.
SEVERE: Error stopping Catalina
java.net.ConnectException: Connection refused (Connection refused)
	at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:607)
	at java.net.Socket.connect(Socket.java:556)
	at java.net.Socket.<init>(Socket.java:452)
	at java.net.Socket.<init>(Socket.java:229)
	at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:667)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:391)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:481)
However the script keeps going  and later I get:
03-Sep-2021 15:28:55.934 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file 03-Sep-2021 15:28:55.949 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [/mgmt] startup failed due to previous errors
The log output:
03-Sep-2021 15:28:55.933 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener] java.lang.UnsupportedClassVersionError: org/epics/archiverappliance/config/ArchServletContextListener has been compiled by a more recent version of the Java Runtime (class file version 56.0), this version of the Java Runtime only recognizes class file versions up to 52.0 (unable to load class [org.epics.archiverappliance.config.ArchServletContextListener])
Could anyone please point me to find a solution.
Fran
Prev: Re: subArray behavior reading just 1 element Lucas Russo via Tech-talk
Next: Re: Quickstart archiver appliance error Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
