1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Quickstart archiver appliance error
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Sun, 5 Sep 2021 15:07:23 +0000
>> java.net.ConnectException: Connection refused (Connection refused)
This is the script trying to stop an earlier instance of Tomcat and not finding any; which is expected.
>> java.lang.UnsupportedClassVersionError: org/epics/archiverappliance/config/ArchServletContextListener has been compiled by a more recent version of the Java Runtime (class file version 56.0), this version of the Java Runtime only recognizes class file versions up to 52.0 (unable to load class
This is an incompatible java version; the JDK you are using is older that what the EPICS archiver appliance distribution was compiled with. Do a "java -version" to check what version you have. Perhaps you can try to use the most recent JDK; most VM's are usually backwards compatible.
Murali
Prev: Quickstart archiver appliance error frangil.ramirez via Tech-talk
Next: Data acquisition storage retrieval, post analysis and visualization. Kuldeep Joshi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
