1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera
From: "Liu, Wanming via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Date: Thu, 9 Sep 2021 21:47:16 +0000
Hi Mark,
It does have a beta version windows program from the vendor which I believe was made using Labview as it depends on Labview runtimes.  That program works fine.  But we need to integrate the camera into our system and that is why I’m trying to use ADAravis.
The user manual has a chapter called “SI Image CMOS TCP/IP Camera Control”.  If I could not make it working with ADAravis, then I will need to go through both that chapter and the areaDetector developer guide  before I can try to program a support module for it.  I hope that I don’t need to go that far.
Thanks for the helps.
Wanming
Sent: Thursday, September 9, 2021 4:19 PM
To: Liu, Wanming <[email protected]>
Cc: [email protected]
Does this camera come with a vendor GUI program, and/or a vendor SDK?  If so, have you tried to run the camera with that vendor software?
Sent: Thursday, September 9, 2021 4:09 PM
Hi Mark,
I just checked the settings on linux machine in the Lab.  It has been configured according to the instruction and the camera wasn’t working there.
I enabled jumbo frame with both NICs in the windows machine in my office and configured the linux virtual machine following the instructions( The camera is connected to one physical NIC which is bridged into the virtual machine).  It doesn’t seem to have any effect.
The next thing I could try is to connect the camera directly to the linux machine in the lab using a crossover cable instead of over the LAN and see how it goes.
Wanming
Sent: Thursday, September 9, 2021 2:11 PM
Hi Wanming,
  • Don't know what to do with MaskedIntReg
  • Don't know what to do with IntReg
Those messages are normal, you can ignore them.
  • When I tried to acquire data from the camera,  the IOC complained about
  • ADAravis::newBufferCallback bad frame status: Timeout
  • or sometimes
  • ADAravis::newBufferCallback bad frame status: Missing Pkts.
Have you set the Linux system parameters for GigE cameras as explained here:
https://areadetector.github.io/master/ADGenICam/ADGenICam.html#linux-usb-and-gige-system-settings
Sent: Thursday, September 9, 2021 1:43 PM
Hi Mark,
Thanks for your response.
When use addCamera.sh in ADGenICam with the XML file extracted with arv-tool-0.8, it shows a bunch of don’t know what to do with IntReg.  Based on the ADAravis documentation, it should be fine.
Then I copied one of the st.cmd…  file into st.cmd.si and modified it as following
< envPaths
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/ADAravisApp.dbd")
ADAravisApp_registerRecordDeviceDriver(pdbbase)
# Name of camera as reported by arv-tool
epicsEnvSet("CAMERA_NAME", "Spectral Instruments, Inc.-1700-139")
# The maximum image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "2048")
# The maximum image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1088")
# Define NELEMENTS to be enough for a 2048x1088 mono image
epicsEnvSet("NELEMENTS", "22228224")
# Enable register caching
epicsEnvSet("ENABLE_CACHING", "1")
# The database file
epicsEnvSet("GENICAM_DB_FILE", "$(ADGENICAM)/db/si.template")
< st.cmd.base
Then I launched IOC and every thing looks fine.  The problem was when I tried to acquire data from the camera.
or sometimes
while no image can be displayed on the OPI.
It might be some camera setting issues or network setting issue.
Thanks for advices
Wanming
Sent: Thursday, September 9, 2021 10:18 AM
Hi Wanming,
Those errors may not prevent ADAravis from working.  For example most but not all cameras have the SensorWidth feature, but ADAravis does not require it.  It does require WidthMax.  Similarly, many cameras do not have a GainRaw feature.
What happens if you run arv-tool-0.8 to extract the XML file, use the Python scripts to generate the template and OPI files, and then try to run an ADAravis IOC with the camera?
From: Tech-talk <[email protected]> On Behalf Of Liu, Wanming via Tech-talk
Sent: Thursday, September 9, 2021 9:54 AM
To: [email protected]
Subject: Using ADAravis with Spectral Instrument 1700 Radiation hard camera
We recently bought a few radiation hard GigE cameras from Spectral Instruments Inc.  I’m just wondering if anybody has any experience using them with ADAravis.
We have no problem using ADAravis with other GigE camera we have.  But so far there is no success with this Spectral Instruments 1700 radiation hard camera.
When I checked it with arv-test-0.8.exe, it reports several errors.
$ arv-test-0.8.exe
Found 1 device
Testing 'Spectral Instruments, Inc.:1700'
Genicam:Load                        SUCCESS
Genicam:Schema                      IGNORED
Properties:SensorSizeReadout        FAILURE node 'SensorWidth' not found
Properties:SensorSizeCheck          IGNORED
Properties:GainReadout              FAILURE node 'GainRaw' not found
Properties:ExposureTimeReadout      SUCCESS
MultipleAcquisition:BufferCheck     FAILURE node 'TriggerSelector' not found
SingleAcquisition:BufferCheck       FAILURE
Chunks:NoSupport                    FAILURE
SoftwareTrigger:NoSupport           FAILURE
GigEVision:NStreamChannels          SUCCESS
GigEVision:StreamChannel            SUCCESS
Any comments and suggestions are appreciated.
Wanming Liu
Re: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Shen, Guobao via Tech-talk
Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Mark Rivers via Tech-talk
RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Prev: Please Unsubscribe Nicholas James Meyler via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Mark Rivers via Tech-talk
Next: Re: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Shen, Guobao via Tech-talk
