1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Veseli, Sinisa" <[email protected]>
Cc: "Nikitin, Viktor" <[email protected]>, "De Carlo, Francesco" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 9 Sep 2021 22:06:02 +0000
On Sep 9, 2021, at 2:38 PM, Veseli, Sinisa via Tech-talk <[email protected]> wrote:
pvapy 4.0.0 uses epics base 7.0.6, while 3.1.0 used 7.0.4.1. However, there were some changes in pvapy 4.0.0 related to support for asynchronous gets that might be causing this.
There were also changes to the caProvider inside pvAccess made between Base 7.0.4.1 and 7.0.5 that made it more strict about saving and restoring the CA context pointer for the current thread, and changed the thread which is used to perform notifications to the PVA client code. That could mean that calling pyepics code from inside a pvaccess callback/notification routine might no longer work if pyepics doesn’t properly set its CA context before calling routines inside libca (unfortunately that’s probably what’s happening, given the access violation that Mark is seeing).
Calling pvaccess routines from inside a pyepics callback should be safe because now the provider routines first save the thread’s current context, set their own context, call libca, and then restore the previous context before returning. However notifications from pvAccess may now be made by a thread that has no attached CA context, and if a libca routine gets called in that context it might trigger this kind of problem.
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
Prev: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Next: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
