1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "Nikitin, Viktor" <[email protected]>, "Veseli, Sinisa" <[email protected]>, "De Carlo, Francesco" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 10 Sep 2021 00:08:11 +0000
It occurred to me later that the situation I was thinking about should only occur if the code was using the CA Provider through the pvaccess API, which is unlikely to be the case here, the code is using pyepics for CA channels and pvapy for PVA channels. However I do think that the access fault you’re seeing is because a thread that is calling libca doesn’t have a CA context.
On Sep 9, 2021, at 5:16 PM, Mark Rivers <[email protected]> wrote:
Ø  That could mean that calling pyepics code from inside a pvaccess callback/notification routine might no longer work if pyepics doesn’t properly set its CA context before calling routines inside libca (unfortunately that’s probably what’s happening, given the access violation that Mark is seeing).
The pyepics call that it crashing is not happening inside a pvaccess callback/notification routine, it is happening in the following code:
class TomoScan():
    def __init__(self, pv_files, macros):
        # Start the watchdog timer thread
        thread = threading.Thread(target=self.reset_watchdog, args=(), daemon=True)
        thread.start()
    def reset_watchdog(self):
        """Sets the watchdog timer to 5 every 3 seconds"""
        while True:
            self.epics_pvs['Watchdog'].put(5)
            time.sleep(3)
So the tomoscan constructor is creating a new thread with threading.Thread.  That thread is running the simple reset_watchdog function, which simply does an epics.PV.put(5) every 3 seconds.  That call crashes with pvaccess 4.0.0 under the following conditions:
-          tomoscan is built with the functions that include pvaccess
or
-          tomoscan is built without pvaccess but PYEPICS_LIBCA is pointing to the version of ca.dll that comes with pvaccess
Does pyepics give access to the libca routines ca_current_context() and ca_attach_context() ? If so I would recommend having that watchdog thread explicitly attach to the context that was created for the main thread. I think that will probably solve the problem if those APIs are available.
- Andrew
Sent: Thursday, September 9, 2021 5:06 PM
To: Veseli, Sinisa <[email protected]>
Cc: Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>; De Carlo, Francesco <[email protected]>; Nikitin, Viktor <[email protected]>
On Sep 9, 2021, at 2:38 PM, Veseli, Sinisa via Tech-talk <[email protected]> wrote:
pvapy 4.0.0 uses epics base 7.0.6, while 3.1.0 used 7.0.4.1. However, there were some changes in pvapy 4.0.0 related to support for asynchronous gets that might be causing this.
There were also changes to the caProvider inside pvAccess made between Base 7.0.4.1 and 7.0.5 that made it more strict about saving and restoring the CA context pointer for the current thread, and changed the thread which is used to perform notifications to the PVA client code. That could mean that calling pyepics code from inside a pvaccess callback/notification routine might no longer work if pyepics doesn’t properly set its CA context before calling routines inside libca (unfortunately that’s probably what’s happening, given the access violation that Mark is seeing).
Calling pvaccess routines from inside a pyepics callback should be safe because now the provider routines first save the thread’s current context, set their own context, call libca, and then restore the previous context before returning. However notifications from pvAccess may now be made by a thread that has no attached CA context, and if a libca routine gets called in that context it might trigger this kind of problem.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Matt Newville via Tech-talk
Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Johnson, Andrew N. via Tech-talk
RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Prev: Re: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Maren Purves via Tech-talk
Next: Re: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Matt Newville via Tech-talk
