1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Alarm Server and archiveEngine
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Hasan SANSAR <[email protected]>
Date: Fri, 10 Sep 2021 12:43:06 +0000
Hi:
As for building, the older Eclipse-based setup can be very difficult.
You might want to try the newer source base, https://github.com/ControlSystemStudio/phoebus
As for running the archive engine, your log seems inconsistent because you're trying to use the config "demo":
> ./ArchiveEngine -pluginCustomization plugin_customization.ini -engine demo
.. but get an error about "Demo":
> Unknown engine 'Demo'
>   at org.csstudio.archive.engine.model.EngineModel.readConfig(EngineModel.java:420)
They are case-sensitive, so I assume it's a copy/paste error?
In any case, you need to first define a configuration before you can use it.
So you first need to create a demo (or Demo) config, import it into the RDB, and then you can use it.
Somewhat like this:
# Create config
cat >demo.xml <<END
<?xml version="1.0" encoding="UTF-8"?>
<engineconfig>
  <group>
    <name>BPLS</name>
    <channel><name>SomeExamplePV</name><period>00:00:01</period><monitor /></channel>
  </group>
</engineconfig>
END
# Import
archive-engine.sh -settings /path/to/settings.ini -engine Demo -import /path/to/demo.xml
# Run sample engine
This is for the current tool where the archive engine and archive config tool are one.
In the older Eclipse-based tools, the ArchiveEngine and the ArchiveConfigTool were separate, but the general idea is the same, as is the XML file format and the RDB setup.
-Kay
Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Prev: Re: Windows: Problem building EPICS base, using MSYS2 & mingw Ralph Lange via Tech-talk
Next: Re: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Next: Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
