1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Alarm Server and archiveEngine
From: Hasan SANSAR via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>
Cc: [email protected]
Date: Sat, 11 Sep 2021 08:41:58 +0300
Hi Kay,
As for building, the older Eclipse-based setup can be very difficult.
You might want to try the newer source base,https://github.com/ControlSystemStudio/phoebus
I will try to built Archive Engine, Alarm Server and SQL schemas from source base of Phoebus. But our client PCs is running CSS 4.5.9. If I do it, could there be conflict between Database Server and Clients? Or else, should I install Phoebus to clients? So, I'm wondering that if we jump to Phoebus on clients, could there be unexpected problems on opis?
They are case-sensitive, so I assume it's a copy/paste error?
Yes, I wrote the command by hand. Sorry for this.
And I found a written documentation about Alarm System Toolkit (with Tomcat, JMS, CSS and etc. tools ) by you. (I attached it that named BEAST.doc) Is there an any documentation for built Alarm Server and/or Archive Engine with Apache Kafka, JMS, Phoebus and etc. tools? (I just read that these modern tools are used in tech-talks while I try to search source code of CSS 4.5.9.)
Hasan Sansar
Attachment: BEAST.doc
Description: MS-Word document
Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Prev: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
