1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Alarm Server and archiveEngine
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Hasan SANSAR <[email protected]>
Date: Mon, 13 Sep 2021 12:19:52 +0000
>source base of Phoebus. But our client PCs is running CSS 4.5.9. If I do
it, could there be conflict between Database Server and Clients? Or
else, should I install Phoebus to clients? So, I'm wondering that if we
jump to Phoebus on clients, could there be unexpected problems on opis?
The original Eclipse-based CS-Studio and the Phoebus version are 100% compatible regarding archived data.
Same RDB schema.
For displays, there is also a high degree of compatibility, see https://github.com/ControlSystemStudio/phoebus/wiki/Display-Builder-Compatibility
> Is there an any documentation for built Alarm Server and/or
Archive Engine with Apache Kafka, JMS, Phoebus and etc. tools?
For alarms, you can export/import the configuration, but the tools are not compatible at runtime because we moved from RDB+JMS to Kafka.
-Kay
Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
Prev: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Next: Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
