1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: modbus TCP
To: liuxiaomin <[email protected]>
Date: Fri, 24 Sep 2021 13:24:52 +0000
> My type of device  at that IP address is MPDU.
I don't know what an MPDU is.  Is this a commercial product, and does it provide Modbus functionality over TCP?  Can you send a link to the product description.
> I changed the IP address. ( 192.168.1.163:8055)
That means you are communicating on port 8055, which is not the standard port for Modbus, which is port 502.  In your original message you were using address "192.168.1.163:502", which is port 502.
Your asynReport shows the the CAT1 asyn port, which is the TCP connection to 192.168.1.163:8055 is OK.
epics> asynReport 1
CAT1 multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
Port 192.168.1.163:8055: Connected
However, the modbus port driver AI1R is not communicating correctly with that CAT1 port driver
modbus port: AI1R
initialized:        true
asynOctet server:   CAT1
modbusSlave:        0
modbusFunction:     3
modbusStartAddress: 010
modbusLength:       02
absoluteAddressing: false
dataType:           0 (INT16)
plcType:
I/O errors:         9
Read OK:            0
Write OK:           0
pollDelay:          0.100000
Time for last I/O   0 msec
Max. I/O time:      0 msec
Time per hist. bin: 1 msec
Note that I./O errors=9 and Read OK and Write OK are both 0.  This means it is not communicating with the device.
How did you chose port 8055 rather than 502?  Are you sure that this device supports Modbus communications on port 502 or some other port?
Sent: Friday, September 24, 2021 5:50 AM
To: Mark Rivers
Cc: [email protected]
Subject: 回复: modbus TCP
Hi Mark,
I am sorry to have sent you two emails,the first one can be ignored.
Thank you for your answer,  My type of device  at that IP address is MPDU.
I changed the IP address.( 192.168.1.163:8055) . And the complete output is as follows:
#!../../bin/linux-x86_64/sinModbus
< envPaths
epicsEnvSet("IOC","iocsinModbus")
epicsEnvSet("TOP","/home/iocusr/sinModbus")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("EPICS_CA_SERVER_PORT", 5064)
#epicsEnvSet("IOCNAME","sinModbus")
dbLoadDatabase "../../dbd/sinModbus.dbd"
sinModbus_registerRecordDeviceDriver pdbbase
#asynReport(10,"CAT1")
# Configure IP port
drvAsynIPPortConfigure("CAT1","192.168.1.163:8055",0,0,1)
# Configure modbus
modbusInterposeConfig("CAT1",0,2000,0)
drvModbusAsynConfigure("AI1R","CAT1",0,3,0010,2,0,100,"CAT")
#cd "${TOP}/iocBoot/${IOC}"
dbLoadRecords "../../db/dbpdu.db", "DEVNAME=TEST"
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-09-13T15:44+0800
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
sevr=info s7plcInit: no stations configured
dbl
TEST:IN1
epics> 2021/09/24 18:14:37.388 drvModbusAsyn::doModbusIO port AI1R error calling writeRead, error=192.168.1.163:8055 timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
After I  typing asynReport 1,the complete output is as follows:
epics> asynReport 1
AI1R multiDevice:Yes canBlock:Yes autoConnect:Yes
nDevices 1 nQueued 0 blocked:No
addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
        exceptionActive No exceptionUsers 0 exceptionNotifys 0
        blocked No
modbus port: AI1R
initialized:        true
modbusSlave:        0
modbusFunction:     3
modbusLength:       02
dataType:           0 (INT16)
plcType:
I/O errors:         9
Read OK:            0
Write OK:           0
pollDelay:          0.100000
Port: AI1R
  Timestamp: <undefined>
  Input EOS[0]:
  Output EOS[0]:
Parameter list 0
Number of parameters is: 12
Parameter 0 type=asynInt32, name=MODBUS_DATA, value is undefined
Parameter 1 type=asynInt32, name=MODBUS_READ, value is undefined
Parameter 2 type=asynUInt32Digital, name=ENABLE_HISTOGRAM, value is undefined
Parameter 3 type=asynInt32, name=READ_HISTOGRAM, value is undefined
Parameter 4 type=asynInt32, name=HISTOGRAM_BIN_TIME, value is undefined
Parameter 5 type=asynInt32Array, name=HISTOGRAM_TIME_AXIS, value is undefined
Parameter 6 type=asynFloat64, name=POLL_DELAY, value is undefined
Parameter 7 type=asynInt32, name=READ_OK, value=0, status=0
Parameter 8 type=asynInt32, name=WRITE_OK, value=0, status=0
Parameter 9 type=asynInt32, name=IO_ERRORS, value=9, status=0
Parameter 10 type=asynInt32, name=LAST_IO_TIME, value=0, status=0
Parameter 11 type=asynInt32, name=MAX_IO_TIME, value=0, status=0
epics>
Then,
$ caget TEST:IN1
CA.Client.Exception…............................................
Warning: “Identical process variable names on multiple servers”
Context: “Channel: “TEST:IN1”, Connecting to: 192.168.1.160:41299, Ignored: 192.168.1.160:5064”
Source File: ../cac.cpp line 1320
Current Time: Fri Sep 24 2021 18:16:53.789456666
TEST:IN1                       0
Finally, I found  the result read value was wrong.
从 Windows 版邮件<https://go.microsoft.com/fwlink/?LinkId=550986>发送
发件人: Mark Rivers<mailto:[email protected]>
发送时间: 2021年9月22日 20:51
收件人: liuxiaomin<mailto:[email protected]>
抄送: [email protected]<mailto:[email protected]>
主题: Re: modbus TCP
Sorry I did not see your second message before I answered your first one.
The st.cmd looks OK to me.  Please send the complete output when the IOC boots.
From: Tech-talk <[email protected]> on behalf of liuxiaomin via Tech-talk <[email protected]>
Sent: Wednesday, September 22, 2021 1:45 AM
To: [email protected]
Subject: modbus TCP
  I am trying to use modbus on debian system to control device,
The st.cmd files is as follows:
drvAsynIPPortConfigure("CAT1","192.168.1.163:502",0,0,1)
drvModbusAsynConfigure("CAT_AI1R","CAT1",0,3,0008,2,0,100, "CAT")
The db files is as follows:
record(ai, "$(DEVNAME):IN1") {
    field(DTYP,"asynInt32")
    field(INP,"@asynMask(CAT_AI1R 0 16)INT16")
    field(PREC,"1")
    field(SCAN,"I/O Intr")
When I execute the st.cmd file,it shows the following error:
TEST:CAT1:IN1 devAsynInt32::initCommon connectDevice failed asynManager:connectDevice port CAT_AI1R not found
How can I solve this problem?
Xiaomin
modbus TCP liuxiaomin via Tech-talk
Re: modbus TCP Mark Rivers via Tech-talk
回复: modbus TCP liuxiaomin via Tech-talk
Prev: 回复: modbus TCP liuxiaomin via Tech-talk
Next: Re: modbus TCP Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
