1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: modbus TCP
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 24 Sep 2021 15:43:36 +0200
On Fri, 24 Sept 2021 at 12:51, liuxiaomin via Tech-talk <[email protected]> wrote:
Then,
$ caget TEST:IN1
CA.Client.Exception…............................................
Warning: “Identical process variable names on multiple servers”
Context: “Channel: “TEST:IN1”, Connecting to: 192.168.1.160:41299, Ignored: 192.168.1.160:5064”
Source File: ../cac.cpp line 1320
Current Time: Fri Sep 24 2021 18:16:53.789456666
TEST:IN1                       0
Careful.
means that you are running two IOCs on the same host that contain the same record.
Please double-check that you killed all running IOCs before starting a new instance.
Cheers,
~Ralph
modbus TCP liuxiaomin via Tech-talk
Re: modbus TCP Mark Rivers via Tech-talk
回复: modbus TCP liuxiaomin via Tech-talk
Prev: Re: modbus TCP Mark Rivers via Tech-talk
Next: Rec Proc Monitor no longer in EPICs 7 record reference documentation. Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Ava in caQtDM Mezger Anton Christian (PSI) via Tech-talk
