1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: High Voltage PS with RS-232 serial port
From: Maren Purves via Tech-talk <[email protected]>
To: Eric Norum <[email protected]>
Cc: EPICS tech-talk <[email protected]>, Hasan SANSAR <[email protected]>
Date: Fri, 1 Oct 2021 08:35:58 -1000
As this is a serial line it can only have one connection.
Did you check that there isn't one before trying to connect?
Aloha,
Maren Purves
On Fri, Oct 1, 2021 at 6:19 AM Eric Norum via Tech-talk
<[email protected]> wrote:
> Here’s a mention of the error message that you reported:
> https://groups.google.com/g/fa.linux.kernel/c/JyHCH2fq-wo?pli=1
> The final message in that thread says:
> The issue was udev loading smsc_ircc2. As soon as smsc_ircc2 is
> loaded, the serial port shows the behavior listed above. Unloading the
> module does not help, a reboot is needed.
> I have now solved the issue locally by blacklisting smsc_ircc2 and
> hope that I didn't break anything in this process.
> Other google search results on "LSR safety check engaged!” imply that perhaps something is messed up in the kernel.
> On Oct 1, 2021, at 4:33 AM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
> Hi all,
> We were using Glassman's HVPS with RS-232 serial port connection diretcly on CentOS 7.4 on MOXA DA-682A. And I updated CentOS to 7.9. after that MOXA PC started to not recognizing RS-232 serial connection. So, we are using High Voltage PS with TCP/IP converter  for temporary reason.
> I'm getting same error in here at tech-talk discussion:
> https://epics.anl.gov/tech-talk/2013/msg01079.php
> > drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
> > asynSetOption("L0", -1, "baud", "9600")
> > setOption failed tcsetattr failed: Input/output error
> How can I solve this problem and how can I connect to this device over RS-232 port again?
> .dmesg | grep tty
> [    0.000000] console [tty0] enabled
> [250769.622609] ttyS0: LSR safety check engaged!
> [251729.802651] ttyS0: LSR safety check engaged!
> [251733.905599] ttyS0: LSR safety check engaged!
> [251733.910846] ttyS0: LSR safety check engaged!
> [251734.006180] ttyS0: LSR safety check engaged!
> Eric Norum
> [email protected]
High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
Re: High Voltage PS with RS-232 serial port Eric Norum via Tech-talk
Prev: Re: High Voltage PS with RS-232 serial port Eric Norum via Tech-talk
Next: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
