1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Sat, 2 Oct 2021 00:28:30 +0000
Hey All,
I couldn’t find a clear explanation on backing up the STS MTS LTS from the archiver appliance and also clearing out the archiverstores after saving them off.  Can I just copy these folders with the protobuf files in it and save them off, if needed I would drop them back into their respective directories if I wanted to use them again?  Am I able to just delete the ArchiverStores after STS MTS LTS have been saved off and they will get remade or would I need to go about this differently?  I tried to look through some of the scripting in the bpl documentation but couldn’t find what I was looking for.  I did find some documentation on saving off configuration of the mysql database, are the config parameters mostly just the PV names and settings for each of the PVs while the data is stored in the protobuff files?
Adam
Prev: Re: High Voltage PS with RS-232 serial port Maren Purves via Tech-talk
Next: Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Fw: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
