1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Fw: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance
From: "Wilson, Andy \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
Date: Tue, 5 Oct 2021 08:04:06 +0000
Replying to copy tech-talk ...
Hi Adam,
I did find some documentation on saving off configuration of the mysql database, are the config parameters mostly just the PV names and settings for each of the PVs while the data is stored in the protobuff files?
Yes, that's right - the archiving parameters are in the database and all the data is in the protobuf files in the stores.
I wouldn't normally be expecting to delete files from the STS or MTS after having backed them up, or to remove the directories themselves. The data is written to the STS, and then the ETL app takes care of moving the data to the MTS and then to the LTS, at the times which you have configured. This means that, once the AA has been running in a steady state for some time, the sizes of the STS and MTS should be more or less constant. The size of the LTS will grow over time, and this is the one that you may need to manage. Note that you can only retrieve data through the AA which is in the data stores. You can remove individual files without affecting retrieval for the other files.
Cheers,
Andy
From: Tech-talk <[email protected]> on behalf of Manoussakis, Adamandios via Tech-talk <[email protected]>
Sent: Saturday, October 2, 2021 01:28
To: EPICS tech-talk <[email protected]>
Subject: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance
Hey All,
I couldn’t find a clear explanation on backing up the STS MTS LTS from the archiver appliance and also clearing out the archiverstores after saving them off.  Can I just copy these folders with the protobuf files in it and save them off, if needed I would drop them back into their respective directories if I wanted to use them again?  Am I able to just delete the ArchiverStores after STS MTS LTS have been saved off and they will get remade or would I need to go about this differently?  I tried to look through some of the scripting in the bpl documentation but couldn’t find what I was looking for.  I did find some documentation on saving off configuration of the mysql database, are the config parameters mostly just the PV names and settings for each of the PVs while the data is stored in the protobuff files?
Adam
Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Manoussakis, Adamandios via Tech-talk
Prev: pvaPy: PvObject - odict_keys not subscriptable issue Kuldeep Joshi via Tech-talk
Next: Re: pvaPy: PvObject - odict_keys not subscriptable issue Veseli, Sinisa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Manoussakis, Adamandios via Tech-talk
Next: Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
