1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Introducing Python package to create Phoebus screens
To: EPICS tech-talk <[email protected]>
Date: Mon, 4 Oct 2021 08:00:00 -0700
Hello All,
I'd like to announce a Python package called Phoebusgen. The module is installable via pip and it allows you to generate Phoebus XML via Python objects. With the package, you will not have to think about any XML elements/tags anymore and you can create scripts to auto generate your screens.
Currently almost every widget is fully supported (38 out of the 41), i.e. any property available in the Display Builder editor is available in Python as a method on the Python widget class.
Examples can be found here: https://github.com/tynanford/phoebusgen/tree/master/examples and feedback and collaboration are welcome.
Tynan
Prev: Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
Next: Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Problems encountered in installing genSub module Johnson, Andrew N. via Tech-talk
Next: Odd characters in temperatures showing in Phoebus Leblanc, Gregory via Tech-talk
