1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Problems encountered in installing genSub module
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 4 Oct 2021 17:18:29 +0000
On Oct 3, 2021, at 10:38 PM, gjzhai via Tech-talk <[email protected]> wrote:
Hello!When I install the gensub module, the error message is displayed as follows when compiling
make[2]: /usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxWorks-6.9/x86-linux2/bin/ccppc: Command not found
make[2]: *** [genSubRecord.0] Error 127
Thank you for your time. I am looking forward to your reply.
The above path is almost the same as the install path to the VxWorks 6.9 C compiler for PowerPC at the APS, except for the ‘W’ character in ‘4.3.3-vxWorks-6.9’ which is lower-case in our installation.
Are you wanting to build this code for PowerPC on VxWorks? I know that Gemini (who created the genSub) also use that architecture, but I don’t see how their gensub module could be causing the above issue. If you are working with or for Gemini you should probably ask them (or Andy Foster) for help.
Do you really need the gensub module at all? A cut-down version of the genSubRecord was added to EPICS Base called the aSub record, and for most applications that should be able to perform the same functions. The aSub is being maintained as part of EPICS Base, whereas I don’t know the status of the gensub module.
- Andrew
Complexity comes for free, simplicity you have to work for.
Problems encountered in installing genSub module gjzhai--- via Tech-talk
Prev: Re: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
Next: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Problems encountered in installing genSub module gjzhai--- via Tech-talk
Next: Introducing Python package to create Phoebus screens Tynan Ford via Tech-talk
