1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: channel and pv deadband
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 4 Oct 2021 18:16:59 +0000
Hi Michael,
many thanks. I tested it out with the changes in dbnd.c and it works perfectly well.
epics is great!
best regards
Anton
Sent: Sunday, October 3, 2021 5:18:59 PM
To: Mezger Anton Christian (PSI)
Cc: EPICS tech-talk; Johnson, Andrew N.; Ralph Lange
On 10/3/21 2:28 AM, Mezger Anton Christian (PSI) via Tech-talk wrote:
> ... Should not the real value 0 then be given later from the monitor when 0 is written?
It should, but until recently this wasn't possible.  A filter
did not have access to the event mask (DBE_*), and so could
not distinguish DBE_VALUE from DBE_VALUE|DBE_ALARM.
This is now possible.  If you would care to test:
https://github.com/epics-base/epics-base/pull/204
channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Kasemir, Kay via Tech-talk
Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Re: channel and pv deadband Johnson, Andrew N. via Tech-talk
Re: channel and pv deadband Michael Davidsaver via Tech-talk
Prev: Re: Problems encountered in installing genSub module Johnson, Andrew N. via Tech-talk
Next: Odd characters in temperatures showing in Phoebus Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: channel and pv deadband Michael Davidsaver via Tech-talk
Next: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
