1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Measurement Computing USB-1608G_2AO support
To: "'Dudley, David'" <[email protected]>
Date: Mon, 18 Oct 2021 23:33:27 +0000
Hi David,
The high level EPICS software already exists in this file, which works on both Linux and Windows.
https://github.com/epics-modules/measComp/blob/master/measCompApp/src/drvMultiFunction.cpp
The low-level Linux driver for the USB-1608G-2A0, written by Warren Jasper, also already exists:
https://github.com/wjasper/Linux_Drivers/blob/master/USB/mcc-libusb/usb-1608G.c
All that needs to be done is to write the “glue layer”, which is the derived class mcBoard_USB-1608G.cpp, in this directory:
https://github.com/epics-modules/measComp/tree/master/measCompApp/cbw_linuxSrc
There are lots of examples, including the mcBoard_E-1608.cpp that can be used as a starting point.
From: Tech-talk <[email protected]> On Behalf Of Dudley, David via Tech-talk
Sent: Monday, October 18, 2021 2:29 PM
To: [email protected]
Subject: Measurement Computing USB-1608G_2AO support
Anyone implemented support for these device under Linux?  measComp module looked real promising until read that only certain modules are supported under Linux, and this one is not one of them.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
Re: Measurement Computing USB-1608G_2AO support Hu, Yong via Tech-talk
Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Prev: Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Next: Can't get device capability and Can't clear buffers 문석호 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Measurement Computing USB-1608G_2AO support Hu, Yong via Tech-talk
