1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Can't get device capability and Can't clear buffers
To: [email protected], [email protected]
Cc: [email protected]
Date: Tue, 19 Oct 2021 17:45:04 +0900
First of all, I'm sorry that sending the reply with different email address.
There is some issue at my university mail system so I send the mail with gmail.
Thanks for your support, Mark Rivers and Eric Norum. However, I faced some other issue with usbtmc.
After I saw the Eric's fixed code. I change the drcAsynUSBTMC.c  file like Eric but I saw the new message like below
The version of asyn and base is 4-26, 3.14.12.5 which is same with past.
I try to use the latest version of asyn but some error occured. I think there is some compatibility issue in my environment so I used the 4-26 version.
But when I check the drcAsynUSBTMC.c file of asyn-4.26 and latest version, there was no difference so I think it is not a problem.
  1. Centos 7 environment (libusb_ver=0.1.4)
  1. Rasberrypi3 environment (libusb_ver=1.0)
In different environment, the epics shows the same message.
To check the usb cable and the dg812 equipment, I communicate with dg812 by using Ultra Sigma(Program of RIGOL) and Ni-Max test panel but there were no error.
Best Regards
SeokHoMoon
Prev: RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
Next: Re: aravisGigE driver for AVT Manta camera Palaha, Arvinder (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Measurement Computing USB-1608G_2AO support Mark L Rivers via Tech-talk
Next: Re: Can't get device capability and Can't clear buffers Mark Rivers via Tech-talk
