1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: ADAravis multiple image mode fail for Basler raL12288-8gm
To: [email protected]
Date: Tue, 19 Oct 2021 12:05:45 -0700
Hi Mark,
We fixed the problem by changing in ADAravis.cpp:
    } else if (imageMode == ADImageMultiple) {
        arv_camera_set_acquisition_mode(this->camera, ARV_ACQUISITION_MODE_MULTI_FRAME, err.get());
to:
        arv_camera_set_acquisition_mode(this->camera, ARV_ACQUISITION_MODE_CONTINUOUS, err.get());
then the acquisition is stopped by:
if ((imageMode == ADImageSingle) ||
                    ((imageMode == ADImageMultiple) &&
                     (numImagesCounter >= numImages))) {
                    this->stopCapture();
David
On Tue, Oct 19, 2021 at 11:37 AM <[email protected]> wrote:
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
        [email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. RE: ADAravis multiple image mode fail for Basler raL12288-8gm
      (Mark Rivers)
   2. RE: ADAravis multiple image mode fail for Basler raL12288-8gm
      (Mark Rivers)
---------- Forwarded message ----------
To: "'Katie Matusik'" <[email protected]>
Cc: "[email protected]" <[email protected]>
Bcc:
Date: Tue, 19 Oct 2021 18:04:17 +0000
Hi Katie,
Ø  We updated ADAravis to R2-2-1. The IOC continuously outputs the following lines:
Ø  2021/10/18 12:15:17.557 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2021/10/18 12:15:18.557 BASLER addr -1 queueRequest priority 0 not lockHolder
Those messages are normal.  I think they are coming because you have enabled ASYN_TRACE_FLOW and/or ASYN_TRACEIO_DRIVER in your st.cmd file.
Ø  and when I try to run in Multiple image mode and acquire 20 images, I get the following:
Ø  ** (process:200574): CRITICAL **: 12:15:19.317: arv_gc_integer_get_value: assertion 'error == NULL || *error == NULL' failed
It may be that the Basler raL12288-8gm does not support MultiFrame mode.
The Basler scA1300-32gm does support it:
corvette:ADGenICam/GenICamApp/Db>grep -U10 AcquisitionMode Basler-scA1300-32gm.template
record(mbbo, "$(P)$(R)GC_AcquisitionMode") {
  field(DTYP, "asynInt32")
  field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_E_AcquisitionMode")
  field(DOL,  "0")
  field(ZRST, "SingleFrame")
  field(ZRVL, "0")
  field(ONST, "MultiFrame")
  field(ONVL, "1")
  field(TWST, "Continuous")
  field(TWVL, "2")
  field(DISA, "0")
However, the Basler does not:
corvette:ADGenICam/GenICamApp/Db>grep -U10 AcquisitionMode Basler_piA640_210gm.template
  field(DOL,  "0")
  field(ZRVL, "0")
  field(ONST, "Continuous")
  field(ONVL, "1")
  field(DISA, "0")
Note that MultiFrame is not in the list of supported modes.
You should look at the template file for your camera and see if MultiFrame is supported.
Sent: Monday, October 18, 2021 2:19 PM
Cc: [email protected]
Subject: Re: ADAravis multiple image mode fail for Basler raL12288-8gm
Hi Mark,
2021/10/18 12:15:18.557 asynManager::portThread port=BASLER callback
2021/10/18 12:15:18.557 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2021/10/18 12:15:18.557 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2021/10/18 12:15:18.557 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2021/10/18 12:15:19.316 BASLER addr -1 queueRequest priority 0 not lockHolder
2021/10/18 12:15:19.316 asynManager::portThread port=BASLER callback
2021/10/18 12:15:19.319 ADGenICam::writeInt32 function=8, value=1, status=0
2021/10/18 12:15:19.319 ADAravis:writeInt32: function=8 ACQUIRE, value=1
2021/10/18 12:15:19.329 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.339 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.349 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.359 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.369 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.379 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.389 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.399 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.409 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.419 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.429 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.439 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.449 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.459 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.469 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.479 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.489 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.499 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.509 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.519 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/18 12:15:19.535 ADAravis:run: acquisition completed
Single and continuous image modes work as expected.
Thanks!
Katie
On Thu, Oct 14, 2021 at 5:31 PM Mark Rivers <[email protected]> wrote:
Hi Katie,
Can you try updating to ADAravis R2-2-1?  That provides improved error message handling so we may be able to see where in the ADAravis driver the error is occurring.
From: Tech-talk <[email protected]> On Behalf Of Katie Matusik via Tech-talk
Sent: Thursday, October 14, 2021 5:26 PM
To: tech-talk <
[email protected]>
Subject: ADAravis multiple image mode fail for Basler raL12288-8gm
I'm using areaDetector-master with ADAravis R2-2 and ADGeniCam R1-7 to control a Basler raL12288-8gm. Continuous and single image modes work fine, but when I try to use Multiple image mode and acquire 10 images, I get the following error in my IOC:
** (process:14182): CRITICAL **: 15:24:34.136: arv_gc_integer_get_value: assertion 'error == NULL || *error == NULL' failed
2021/10/14 15:24:34.148 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.158 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.168 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.178 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.188 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.198 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.208 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.218 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.228 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
2021/10/14 15:24:34.238 ADAravis:processBuffer: w: 12288, h: 1, size: 0, expected_size: 24576
Please let me know what further information may be useful.
Thanks so much,
Katie
Image removed by sender.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
Bcc:
Date: Tue, 19 Oct 2021 18:36:57 +0000
I meant to say:
“However, the Basler piA640_210gm does not:”
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Tuesday, October 19, 2021 1:04 PM
To: 'Katie Matusik' <[email protected]>
Hi Katie,
  field(DOL,  "0")
  field(ZRVL, "0")
  field(ONVL, "1")
  field(TWVL, "2")
  field(DISA, "0")
  field(DOL,  "0")
  field(ZRVL, "0")
  field(ONVL, "1")
  field(DISA, "0")
Hi Mark,
Thanks!
Katie
Hi Katie,
To: tech-talk <
[email protected]>
Thanks so much,
Katie
Katie Matusik
Systems Engineer
Tech-talk mailing list [email protected]
RE: ADAravis multiple image mode fail for Basler raL12288-8gm Mark Rivers via Tech-talk
Prev: Re: aravisGigE driver for AVT Manta camera Hasan SANSAR via Tech-talk
Next: RE: ADAravis multiple image mode fail for Basler raL12288-8gm Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: ADAravis multiple image mode fail for Basler raL12288-8gm Mark Rivers via Tech-talk
