1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: stream install error
To: tech-talk <[email protected]>
Date: Wed, 20 Oct 2021 17:36:10 +0800 (CST)
Hi all,
    I met a questiong about stream module.
    I downloaded stream module from github( https://github.com/paulscherrerinstitute/StreamDevice  )
    Centos 8(64), base-7.0.6.1, stream
stream release file
---------------RELEASE File-------------------------
SUPPORT=/home/liangyx/synApps/support
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
ASYN=$(SUPPORT)/asyn-master
CALC=$(SUPPORT)/calc-master
SSCAN=$(SUPPORT)/sscan-master
PCRE=/home/liangyx/synApps/other_software/pcre-8.45
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=/home/liangyx/base-7.0.6.1
-include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
---------------------End---------------------------------
And I got the error when make : ( "libpcre.a', needed by 'libstream.so'." )
--------------------------------Error-------------------------------------
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/liangyx/synApps/support/StreamDevice-master/src/O.linux-x86_64'
make[2]: *** No rule to make target '../../lib/linux-x86_64/libpcre.a', needed by 'libstream.so'.  Stop.
make[2]: Leaving directory '/home/liangyx/synApps/support/StreamDevice-master/src/O.linux-x86_64'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/StreamDevice-master/src'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: src.install] Error 2
----------------------------------End------------------------------------
1)
I tried to copy libpcre.a to "../../lib/linux-x86_64/", it did not worked.
How should I slove the question?
2)
When I changed the pc, I would reinstall the epics and other software again.  It is quite stupid and time waste.
Some suggestion about the question?
Thank you.
Liang
Re: stream install error Ralph Lange via Tech-talk
Prev: Re: xxx moduld make error Simon Rose via Tech-talk
Next: Re: stream install error Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
