On Wed, 20 Oct 2021 at 11:36, 网易邮件中心 via Tech-talk <tech-talk at aps.anl.gov> wrote:
If you want to compile StreamDevice with pcre support, you need to install the pcre package on your system first, then tell stream where the library is located. More details for setting up StreamDevice are available at https://paulscherrerinstitute.github.io/StreamDevice/setup.html Cheers, ~Ralph
ANJ, 20 Oct 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
