1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Re:RE: motor module make error
To: 网易邮件中心 <[email protected]>
Date: Fri, 22 Oct 2021 13:26:18 +0000
Hi Liang,
The error you are getting was fixed in this commit in 2019:
https://github.com/epics-motor/motorOms/commit/261383e11f8ce8fb3dad4e8c531e13a73405874c#diff-da9f8aee7822265d97f40e2bfa61fab84ae3828cda87aa2458130bbc2bf29292
Sent: Friday, October 22, 2021 5:10 AM
To: Mark Rivers
Cc: tech-talk; [email protected]; [email protected]
Subject: Re:RE: motor module make error
Hi all,
    Thank you for your kind answer.
     It was good for centos 8,  base-7.0.6.1 and motor-master.   Sorry, I described the question wrongly.
    It was good motor-master.
    But i found that the file ( motor-master/module/)  was empty.
    So I copied "motorAMCI,motor* files" from synApps_6_1  to motor-master/module.
    Then the error came out.
    Today, I unzip the motor-master.zip and make, it was good.
     But how should i do it, to add the motorAMCI,motorKohzu in /module/ file?
Liang
$ gcc --versiongcc (GCC) 8.4.1 20200928 (Red Hat 8.4.1-1)
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ uname -r
4.18.0-305.19.1.el8_4.x86_64
At 2021-10-22 06:24:26, "Mark Rivers" <[email protected]> wrote:
Hi Liang,
I just built that file on Centos 8 using gcc 8.4.1-1.  It builds fine for me.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/corvette/home/epics/devel/motor-7-0/include/compiler/gcc -I/corvette/home/epics/devel/motor-7-0/include/os/Linux -I/corvette/home/epics/devel/motor-7-0/include   -I/corvette/home/epics/devel/motor-7-0/include   -I/corvette/home/epics/devel/asyn-4-42/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/busy-1-7-2/include   -I/corvette/home/epics/devel/ipac-2-15/include -I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.5/include           -c ../drvOmsPC68.cc
In file included from /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccess.h:20,
                 from ../drvOmsPC68.cc:72:
/corvette/usr/local/epics-devel/base-7.0.5/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
     rset            *prset;
In file included from /corvette/usr/local/epics-devel/base-7.0.5/include/dbBase.h:22,
/corvette/usr/local/epics-devel/base-7.0.5/include/recSup.h:89:21: note: declared here
typedef struct rset rset EPICS_DEPRECATED;
In file included from /corvette/usr/local/epics-devel/base-7.0.5/include/dbAccess.h:24,
/corvette/usr/local/epics-devel/base-7.0.5/include/dbAccessDefs.h:211:59: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
epicsShareFunc rset * dbGetRset(const struct dbAddr *paddr);
../drvOmsPC68.cc: In function ‘int omsGet(int, char*)’:
../drvOmsPC68.cc:660:17: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
     asynStatus  status;
../drvOmsPC68.cc: In function ‘void asynCallback(void*, asynUser*, char*, size_t, int)’:
../drvOmsPC68.cc:687:7: warning: suggest explicit braces to avoid ambiguous ‘else’ [-Wdangling-else]
     if( stat & STAT_DONE )
What version of gcc are you using?  (gcc ?version).
From: Tech-talk <[email protected]> On Behalf Of ?????? via Tech-talk
Sent: Wednesday, October 20, 2021 10:23 PM
To: tech-talk <[email protected]>
Subject: motor module make error
Hi all,
     I use centos8, base 7.0.6.1, motor ( https://github.com/epics-modules/motor ), seq-2.2.6, and some other module from https://github.com/epics-modules/.<https://github.com/epics-modules/>
    I got the error message.
--------------------Error----------------------------------------
make -C ./modules install
make[1]: Entering directory '/home/liangyx/synApps/support/motor-master/modules'
make -C ./motorOms install
make[2]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms'
make -C ./configure install
make[3]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64'
perl -CSD /home/liangyx/base-7.0.6.1/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure/O.linux-x86_64'
make[3]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/configure'
make -C ./omsApp install
make[3]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp'
make -C ./src install
make[4]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[5]: Entering directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/home/liangyx/synApps/support/motor-master/include/compiler/gcc -I/home/liangyx/synApps/support/motor-master/include/os/Linux -I/home/liangyx/synApps/support/motor-master/include   -I/home/liangyx/synApps/support/motor-master/include   -I/home/liangyx/synApps/support/asyn-master/include   -I/home/liangyx/synApps/support/seq-2.2.6/include   -I/home/liangyx/synApps/support/busy-master/include   -I/home/liangyx/synApps/support/ipac-master/include -I/home/liangyx/base-7.0.6.1/include/compiler/gcc -I/home/liangyx/base-7.0.6.1/include/os/Linux -I/home/liangyx/base-7.0.6.1/include           -c ../drvOmsPC68.cc
In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:20,
/home/liangyx/base-7.0.6.1/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
     rset            *prset;
In file included from /home/liangyx/base-7.0.6.1/include/dbBase.h:22,
/home/liangyx/base-7.0.6.1/include/recSup.h:89:21: note: declared here
In file included from /home/liangyx/base-7.0.6.1/include/dbAccess.h:24,
/home/liangyx/base-7.0.6.1/include/dbAccessDefs.h:210:55: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
 DBCORE_API rset * dbGetRset(const struct dbAddr *paddr);
../drvOmsPC68.cc:110:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
 static char *oms_axis[] = {"X", "Y", "Z", "T", "U", "V", "R", "S"};
../drvOmsPC68.cc:148:1: error: invalid conversion from ‘RTN_STATUS (*)(int, const char*, char*)’ {aka ‘RTN_VALUES (*)(int, const char*, char*)’} to ‘RTN_STATUS (*)(int, const char*, const char*)’ {aka ‘RTN_VALUES (*)(int, const char*, const char*)’} [-fpermissive]
../drvOmsPC68.cc:148:1: error: invalid conversion from ‘char**’ to ‘const char**’ [-fpermissive]
make[5]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_BUILD:263: drvOmsPC68.o] Error 1
make[5]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src/O.linux-x86_64'
make[4]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp/src'
make[3]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: src.install] Error 2
make[3]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms/omsApp'
make[2]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: omsApp.install] Error 2
make[2]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules/motorOms'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: motorOms.install] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/motor-master/modules'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: modules.install] Error 2
--------------------End----------------------------------------
I could not find the problem
Could someone give me some advice.
Liang
motor module make error 网易邮件中心 via Tech-talk
Re:RE: motor module make error 网易邮件中心 via Tech-talk
Prev: Data Browser (phoebus) auto data fetching from an Archiver Appliance BENEDETTI Florian via Tech-talk
Next: Re: [EXTERNAL] Data Browser (phoebus) auto data fetching from an Archiver Appliance Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: motor module make error Torsten Bögershausen via Tech-talk
Next: QuadEM operation with parameters "Queued" Iain Marcuson via Tech-talk
