1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: undefine variable in RELEASE.local
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 26 Oct 2021 21:13:23 +0000
Hi Andrew,
That patch does indeed fix it, thanks!
I should have mentioned that I was using base 7.0.6, and I didn’t realize I was using a new feature from 7.0.5, and I wasn’t too familiar with how the RELEASE files are parsed, but it makes sense now.
Cheers,
Matt
Sent: Tuesday, October 26, 2021 4:22 PM
To: Pearson, Matthew R. <[email protected]>
Subject: [EXTERNAL] Re: undefine variable in RELEASE.local
Hi Matt,
On Oct 26, 2021, at 9:26 AM, Pearson, Matthew R. via Tech-talk <[email protected]> wrote:
undefine SNCSEQ
EPICS_BASE=/home/controls/common/base/main
Although this causes errors like these when building asyn:
make[2]: Entering directory '/home/controls/common/asyn/main/iocBoot/ioctest'
perl -CSD /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl -t /home/controls/common/asyn/main envPaths
Use of uninitialized value $iocpath in substitution (s///) at /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl line 220.
Use of uninitialized value $path in -d at /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl line 221.
Oops! This patch to Base should fix the problem, please try it:
diff --git a/src/tools/EPICS/Release.pm b/src/tools/EPICS/Release.pm
index 7caa6f4c6..e6aaf1e0c 100644
--- a/src/tools/EPICS/Release.pm
+++ b/src/tools/EPICS/Release.pm
@@ -67,6 +67,7 @@ sub readRelease {
         my ($uvar) = m/^ undefine \s+ ($MVAR)/x;
         if ($uvar ne '') {
             delete $Rmacros->{$uvar};
+            @$Rapps = grep($_ ne $uvar, @$Rapps);
             next;
Do you know what's causing these errors? I suppose the script just isn't silently dealing with the 'undefine' syntax?
Yup, and I evidently didn’t test the code properly when I added support for undefine (in Base 7.0.5 I believe).
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
undefine variable in RELEASE.local Pearson, Matthew R. via Tech-talk
Prev: Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
Next: Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
