1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: undefine variable in RELEASE.local
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
Date: Tue, 26 Oct 2021 14:26:21 +0000
I've been attempting to build a set of support modules by leaving the RELEASE files unchanged and only specifying what we need in RELEASE.local files.
So up until now I have only ever built asyn with a single dependency on base, and so my asyn RELEASE.local contains:
EPICS_BASE=/home/controls/common/base/main
However this fails because the standard asyn RELEASE file sets:
# SEQ is required for testIPServer
SNCSEQ=$(SUPPORT)/seq-2-2-5
And so the asyn build fails because that particular test expects SNCSEQ.
To fix that in my asyn RELEASE.local I can do:
SNCSEQ=
But that causes problems on downstream builds that also use SNCSEQ due to CHECK_RELEASE.
I can fix that by doing this instead:
undefine SNCSEQ
Although this causes errors like these when building asyn:
make[2]: Entering directory '/home/controls/common/asyn/main/iocBoot/ioctest'
perl -CSD /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl -t /home/controls/common/asyn/main envPaths
Use of uninitialized value $iocpath in substitution (s///) at /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl line 220.
Use of uninitialized value $path in -d at /home/controls/common/base/main/bin/linux-x86_64/convertRelease.pl line 221.
Do you know what's causing these errors? I suppose the script just isn't silently dealing with the 'undefine' syntax? However, it seems to complete fine, as the envPaths file is correct:
epicsEnvSet("IOC","ioctest")
epicsEnvSet("TOP","/home/controls/common/asyn/main")
epicsEnvSet("EPICS_BASE","/home/controls/common/base/main")
Cheers,
Matt
STS Integrated Control System Lead Engineer
Spallation Neutron Source
Oak Ridge National Lab
Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
Prev: RE: Measurement Computing USB-1608G_2AO support Mark L Rivers via Tech-talk
Next: Control System Engineer position at ALS in LBNL Miroslaw Dach via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: [EXTERNAL] Data Browser (phoebus) auto data fetching from an Archiver Appliance BENEDETTI Florian via Tech-talk
Next: Re: undefine variable in RELEASE.local Johnson, Andrew N. via Tech-talk
