1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: IOC in Docker not responding to caget from another host
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Thu, 28 Oct 2021 02:54:31 +0000
This is the scenario:
In HostA I have one container running an IOC and another container with caget/caput installed. Both containers have these env variables defined:
EPICS_CA_ADDR_LIST=127.255.255.255
EPICS_CA_REPEATER_PORT=5065
EPICS_CA_SERVER_PORT=5064
I can caget in one container and receive data from the IOC. When both are in the same host it works well. With tcpdump I can see the traffic between the two containers, using localhost to communicate.
The containers are running with network host mode.
Now I want to run caget in HostB that is in a different network. In HostB I've defined:
EPICS_CA_ADDR_LIST=134.79.219.255
With tcpdump in HostA, I can see that 5 caget requests arrive from HostB to HostA, but the IOC doesn't seem to be aware of the packages. I understand that the IOC responds to broadcast requests coming from any of the interfaces by default. Is that right?
Any clues? If you need more data, I'm happy to add them to this thread.
Thank you,
Márcio Paduan Donadio | Control Systems Engineer
Advanced Control Systems Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.5007 | w: slac.stanford.edu
Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
Re: IOC in Docker not responding to caget from another host Pete Jemian via Tech-talk
Prev: RE: QuadEM operation with parameters "Queued" Iain Marcuson via Tech-talk
Next: Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: synApps motor build Siddons, David via Tech-talk
