1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: IOC in Docker not responding to caget from another host
From: Lucas Russo via Tech-talk <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 28 Oct 2021 09:59:16 -0300
Hi Marcio,
One suggestion I have is checking if the iptables rules are indeed applied.
I have the following in my test machine:
lerwys@lerwys-dig:~$ sudo iptables -L -t nat
Chain PREROUTING (policy ACCEPT)
target     prot opt source               destination
DOCKER     all  --  anywhere             anywhere             ADDRTYPE match dst-type LOCAL
DNAT       udp  --  anywhere             lerwys-dig           udp dpt:5064 to:172.17.255.255
172.17.0.1/16 is my docker network
Lucas
On Thu, Oct 28, 2021 at 3:56 AM Florian Feldbauer via Tech-talk <[email protected]> wrote:
Hey Marcio,
one think that comes to my mind: If you run the IOCs in containers with network mode host there might be multiple caRepeaters now listening on the same IP address and ports as each IOC might start its own caRepeater within its container.
If you start multiple IOC on the same host without containers there will be only one instance of the caRepeater process.
I'm not sure if this might cause your problem.
Best regards,
Florian
On 10/28/21 4:54 AM, Paduan Donadio, Marcio via Tech-talk wrote:
This is the scenario:
In HostA I have one container running an IOC and another container with caget/caput installed. Both containers have these env variables defined:
EPICS_CA_ADDR_LIST=127.255.255.255
EPICS_CA_REPEATER_PORT=5065
EPICS_CA_SERVER_PORT=5064
I can caget in one container and receive data from the IOC. When both are in the same host it works well. With tcpdump I can see the traffic between the two containers, using localhost to communicate.
The containers are running with network host mode.
Now I want to run caget in HostB that is in a different network. In HostB I've defined:
EPICS_CA_ADDR_LIST=134.79.219.255
With tcpdump in HostA, I can see that 5 caget requests arrive from HostB to HostA, but the IOC doesn't seem to be aware of the packages. I understand that the IOC responds to broadcast requests coming from any of the interfaces by default. Is that right?
Any clues? If you need more data, I'm happy to add them to this thread.
Thank you,
Márcio Paduan Donadio | Control Systems Engineer
Advanced Control Systems Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.5007 | w: slac.stanford.edu
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
Prev: Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
Next: Failed connection using e3-s7plc to Siemens S7-1500 Mateusz Nabywaniec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
