1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: Plotting images in Phoebus
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Smith, William" <william.smith at helmholtz-berlin.de>
Date: Thu, 28 Oct 2021 16:35:23 +0000
The axis min/max is independent from the image size.
You can enter any numbers for the X or Y axis range, like 0 .. 100 or 100 .. 0 or -50 .. 50  or 50 .. -50.
"Minumum" doesn't have to be less than "maximum".
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Smith, William via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, October 28, 2021 12:25 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Plotting images in Phoebus
Hi
I would like to display images using Phoebus. If I use the image widget it shows axes starting from 0 in the bottom left, however it displays the image with the origin in the top left, as is convention https://matplotlib.org/stable/tutorials/intermediate/imshow_extent.html
Is it possible to configure which way round the axes of the image (and other plot) widgets are displayed?
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Plotting images in Phoebus Smith, William via Tech-talk
Prev: Plotting images in Phoebus Smith, William via Tech-talk
Next: Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Next: Does camonitor update when the record processes? Wang, Andrew via Tech-talk
ANJ, 29 Oct 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
