1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Does camonitor update when the record processes?
From: "Wang, Andrew via Tech-talk" <[email protected]>
Date: Fri, 29 Oct 2021 07:19:27 +0000
Hi all,
Quick question. So I have noticed that when we run camonitor for a record called "foo", it initially doesn't show a time stamp. When I then do caput foo.PROC 1, camonitor updates with a new entry containing a time stamp, which I assume is the time at which the processing occurred. However when I do caput foo.PROC 1 again, camonitor doesn't update. This has me thinking that it is just for monitoring value changes and not meant for monitoring processing. If we want to know if a record has been processed, it is better to use TPRO. Please correct me if I am wrong.
Andy
Re: Does camonitor update when the record processes? Johnson, Andrew N. via Tech-talk
Prev: Re: IOC in Docker not responding to caget from another host Michael Davidsaver via Tech-talk
Next: ODP: Failed connection using e3-s7plc to Siemens S7-1500 Mateusz Nabywaniec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Plotting images in Phoebus Kasemir, Kay via Tech-talk
Next: Re: Does camonitor update when the record processes? Johnson, Andrew N. via Tech-talk
