1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: nPoint motor driver
From: Kevin Peterson via Tech-talk <[email protected]>
To: Randall Cayford <[email protected]>, "Engbretson, Mark S. via Tech-talk" <[email protected]>
Date: Mon, 8 Nov 2021 13:29:00 -0600
Randall,
This database contains records that allow setting wavetable parameters:
https://github.com/epics-motor/motorNPoint/blob/4d8b0d1cc0dc78315f8dad1279fd53a1e4cac0ce/nPointApp/Db/LC400_auxParameters.db#L88-L192
The driver loads a wavetable profile for each point-to-point move (changing the motor's VAL field). profileMove functionality is not currently implemented.
Kevin
On 11/5/21 12:52, Randall Cayford via Tech-talk wrote:
I’m trying to set up an nPoint LC402 motor controller and I can’t figure out how to load the motor positions.  There is a driver in the synApps motor modules and the documentation talks a lot about controlling the stepping through the wavetable but I can’t figure out what PVs I’m supposed to use to set the wavetable values.
Does anyone know how to upload the wavetable to an nPoint controller?
Randall
Re: nPoint motor driver Randall Cayford via Tech-talk
Prev: Re: Archiver Appliance sometimes stops archiving some PVs or loses points Shankar, Murali via Tech-talk
Next: RE: Archiver Appliance sometimes stops archiving some PVs or loses points Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: nPoint motor driver Randall Cayford via Tech-talk
Next: Re: nPoint motor driver Randall Cayford via Tech-talk
