Thanks Kevin.
I’ve got those records but I’m not clear on what you mean. None of those PVs appear to set a wavetable entry. Are you saying that the current implementation only allows keeping the wavetable in the outside program and issuing a series of moves by setting the val motor field, waiting, and setting the next? So not using the ability of the nPoint to do custom wavetables at all? Is loading a custom wavetable what you mean by profileMove isn’t implemented?
Randall
> On Nov 8, 2021, at 11:29 AM, Kevin Peterson <kmpeters at anl.gov> wrote:
> Randall,
> This database contains records that allow setting wavetable parameters:
> https://github.com/epics-motor/motorNPoint/blob/4d8b0d1cc0dc78315f8dad1279fd53a1e4cac0ce/nPointApp/Db/LC400_auxParameters.db#L88-L192
> The driver loads a wavetable profile for each point-to-point move (changing the motor's VAL field). profileMove functionality is not currently implemented.
> Kevin
> On 11/5/21 12:52, Randall Cayford via Tech-talk wrote:
>> I’m trying to set up an nPoint LC402 motor controller and I can’t figure out how to load the motor positions. There is a driver in the synApps motor modules and the documentation talks a lot about controlling the stepping through the wavetable but I can’t figure out what PVs I’m supposed to use to set the wavetable values.
>> Does anyone know how to upload the wavetable to an nPoint controller?
>> Randall
- Re: nPoint motor driver Kevin Peterson via Tech-talk
- nPoint motor driver Randall Cayford via Tech-talk
RE: Archiver Appliance sometimes stops archiving some PVs or loses points Manoussakis, Adamandios via Tech-talk
EPICS support for the Omega Platinum Series PID Controllers Wlodek, Jakub via Tech-talk
<2021>
2025
<2021>
2025
