1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: StreamDevice Format Converters
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Ralph Lange via Tech-talk <[email protected]>
Date: Fri, 12 Nov 2021 11:18:13 +0100
I receive a string from a device containing the current draw as a 6 character number. ie. for 2.45 A, the string would be 000245. Using the format converter %6f in the proto file, I am able to read the value into a ai record as 245. However when I try to convert the input string using %=6.2f, I always read in 0 as the current.
Am I understanding the = operator properly? How can I convert the string 000245 input into 2.45 in the ai record?
Thank you in advance,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Re: StreamDevice Format Converters Ralph Lange via Tech-talk
Prev: Access motor controller target positions of other axes in asynMotorAxis::move Laurenz Rettig via Tech-talk
Next: Re: Access motor controller target positions of other axes in asynMotorAxis::move Mark L Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: [EXTERNAL] Re: Access motor controller target positions of other axes in asynMotorAxis::move Mark L Rivers via Tech-talk
Next: Re: StreamDevice Format Converters Ralph Lange via Tech-talk
