1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: StreamDevice Format Converters
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Sun, 14 Nov 2021 12:52:57 +0100
Hi Donny,
On Fri, 12 Nov 2021 at 11:18, Donny Domagoj Cosic via Tech-talk <[email protected]> wrote:
I receive a string from a device containing the current draw as a 6
character number. ie. for 2.45 A, the string would be 000245. Using the
format converter %6f in the proto file, I am able to read the value into
a ai record as 245. However when I try to convert the input string using
%=6.2f, I always read in 0 as the current.
Am I understanding the = operator properly? How can I convert the string
000245 input into 2.45 in the ai record?
I would convert the string to an integer (which it basically is) to have it written to the RVAL (raw value) field of the ai record and use the standard linear conversion function of the ai (setting LINR to SLOPE and ESLO to the desired factor) to convert it to the value in engineering units.
StreamDevice's = operator is used to *compare* an input string with a value. (E.g., for an output record, if your device's return string contains the value that you just set, you can make sure that it matches.)
Cheers,
~Ralph
StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Prev: RE: Access motor controller target positions of other axes in asynMotorAxis::move Mark L Rivers via Tech-talk
Next: Fwd: StreamDevice Format Converters Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
