1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: AppImages for EPICS base
From: "Zhang, Tong via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 15 Nov 2021 16:40:21 +0000
Dear Colleagues,
I've just published wheel packages for the EPICS base tools, i.e. caget, caput, softIoc, etc. onto PyPI (see the link below). They are AppImages built from EPICS base source code, tagged with the same release versions.
The intention is to use EPICS base CLI tools without building from source code at the target platform. AppImage is one of the solutions on Linux that could solve the binary distribution problem.
The simplest way to use it is: 'pip install epics-appimage', then a collection of EPICS CA/PV tools is available to use by typing the command name in the terminal.
I've tested on Debian and its derivatives, as well as CentOS 8, others released later than Ubuntu 16.04 should also work.
Here are the hyperlinks:
* PyPI project: https://pypi.org/project/epics-appimage
* GitHub project: https://github.com/archman/epics-appimage
Feel free to create an issue if you have any questions, thanks.
P.S. This work is also inspired by Michael Davidsaver's epicscorelibs project.
Tong
Re: AppImages for EPICS base Pete Jemian via Tech-talk
Prev: RE: [EXTERNAL] Re: Access motor controller target positions of other axes in asynMotorAxis::move Pearson, Matthew R. via Tech-talk
Next: Help with Blackfly FLIR/PointGrey Camera Smith, William via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: R3-3 of ADSpinnaker Mark L Rivers via Tech-talk
Next: Re: AppImages for EPICS base Pete Jemian via Tech-talk
