1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: R3-3 of ADSpinnaker
From: Mark L Rivers via Tech-talk <[email protected]>
Date: Sun, 14 Nov 2021 23:45:30 +0000
Folks,
ADSpinnaker R3-3 is available.  This is from the release notes:
* Fixed a problem reading Integer GenICam feature values, and their min and max.
  The values were being cast from Int64 to Int32.  This was not correct.
  This was a problem, for example, with values whose maximum was 2^32-1, because the maximum was read as -1.
  This resulted in not being able to set the value, since the allowed maximum was less than the allowed minimum.
https://github.com/areaDetector/ADSpinnaker
Prev: Fwd: StreamDevice Format Converters Zimoch Dirk (PSI) via Tech-talk
Next: Re: StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: StreamDevice Format Converters Donny Domagoj Cosic via Tech-talk
Next: AppImages for EPICS base Zhang, Tong via Tech-talk
