Folks,
R3-1 of ADEiger is available. This is from the release notes:
Fixed a race condition with the Stream interface.
The detector sends the first message over the ZMQ socket as soon as the "arm" command is sent when starting acquisition.
However, the driver was not creating the ZMQ socket to receive those messages until after the "arm" command was sent. This was a race condition. It was failing on an Eiger2 at APS sector 34.
This release creates the ZMQ socket before acquisition begins.
Added "epsilon" PVs EnergyEps and WavelengthEps. Thanks to Bruno Martins for this.
These are used to prevent minute or accidental changes to Energy and Wavelength from taking too long to be applied. Their values are now only updated if the difference between the desired and
current value is greater than some configurable parameters. Specifically, changes in Wavelength only take effect if they result in a difference greater than WavelengthEps (default: 0.0005 Angstroms). Similarly, changes to PhotonEnergy, Threshold and Threshold2
only take effect if they are greater than EnergyEps (default: 0.05 eV).
Improved the error diagnostic messages in the Stream API.
https://github.com/areaDetector/ADEiger
Re: Understanding Motor Record Kevin Peterson via Tech-talk
Re: Re: Re: A problem with modbus reading floating point numbers 高振华 via Tech-talk
<2021>
2025
Dante R1-1 released Mark L Rivers via Tech-talk
ADEiger/Filewriter question John Dobbins via Tech-talk
<2021>
2025
ANJ, 20 Nov 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
