1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Phoebus Image Decompression
From: "Smith, William via Tech-talk" <[email protected]>
To: Mark L Rivers <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Mon, 22 Nov 2021 18:58:20 +0000
Cool, if I find time I will give this a go and raise a pull request. Thanks Mark and Kay for the help (again!!)
Will
-----Original Message-----
Sent: Monday, November 22, 2021 7:12 PM
To: Kasemir, Kay <[email protected]>; Smith, William <[email protected]>
There is Java code to decompress all of the supported areaDetector codecs in NDPluginCodec in ADViewers.
https://github.com/areaDetector/ADViewers/tree/master/ImageJ/EPICS_areaDetector
These are just wrappers around the C/C++ codecs in ADSupport which are built as shareable libraries.
From: Tech-talk <[email protected]> On Behalf Of Kasemir, Kay via Tech-talk
Sent: Monday, November 22, 2021 11:33 AM
To: [email protected]; Smith, William <[email protected]>
Subject: Re: Phoebus Image Decompression
Hi Will,
> Does Phoebus image viewer work with area detector compressed images sent over PV access? I.E can it read the compression type from the PV access protocol and perform the decompression?
At this time, regrettably, no. The relevant code is in https://github.com/ControlSystemStudio/phoebus/blob/master/core/pv/src/main/java/org/phoebus/pv/pva/ImageDecoder.java
In principle, it's straight forward to add something like `struct.get("compression")` to determine how the data is compressed, and to then un-compress the `value`.
If you have some actual test data and information on how to decode the compressed image, please go ahead and implement it.
Kay
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Phoebus Image Decompression Smith, William via Tech-talk
Re: Phoebus Image Decompression Kasemir, Kay via Tech-talk
RE: Phoebus Image Decompression Mark L Rivers via Tech-talk
Prev: RE: Phoebus Image Decompression Mark L Rivers via Tech-talk
Next: Alternative to EPICS Gateway Wilkins, Stuart via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Control Systems Developer + DevOps Role at Fusion Startup Josh Fiddler via Tech-talk
