Hi Ralph,
I only have a basic understanding of how the channel access protocol works, but my understanding is that the client just makes a socket connection to a port and then sends the channel access commands.
I might be making some incorrect assumptions, but I think that if to get the host from your local machine's perspective you send some channel access commands to a local port, then to get the host from the gateway machine's perspective you can just make a socket
connection to the right port on the gateway machine and send the same commands, without needing to ssh in the gateway machine. Do you know if this is how it works?
Alex
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, November 24, 2021 2:44:50 AM To: EPICS Tech Talk <tech-talk at aps.anl.gov> Subject: Re: Finding the server where a PV's IOC is located On Tue, 23 Nov 2021 at 21:41, Sobhani, Bayan via Tech-talk <tech-talk at aps.anl.gov> wrote:
Using Channel Access? No.
Many installations (including NSLS 2 btw.) are using the ChannelFinder directory service to collect and provide that kind of information.
Cheers,
~Ralph
ANJ, 28 Nov 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
