1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 30 Nov 2021 01:32:52 +0000
Hey All,
I am trying to make sure I understand how the CA Gateway networking setup works for running all pieces on the same PC(VM).  Below is my ENV variables list that I setup, I am just using the basic access list and pv list examples (although I did have a question about the access/pvlist)
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
export EPICS_CA_MAX_ARRAY_BYTES=800000
export EPICS_CAS_INTF_ADDR_LIST=localhost
export EPICS_CA_SERVER_PORT=5064
export EPICS_CAS_SERVER_PORT=5065
My understanding is that the CAS port is listening for requests from a client (in this case Phoebus).  I also am running Ralphs script to handle multiple IOCs on the same PC so UDP packets sent to 5064 are being echoed out on all ports (I think I need to block whichever port the CAS Server Port in this NAT Rule to stop looping).  Below is how I think the setup is supposed to work but I am unsure as I havnt been successful yet.
Phoebus PV UDP Request,NAT UDP Echoing Rule
5064 -> Broadcast
(Block 5068)
,IOC 1
Dynamic Port
,IOC 2
Dynamic Port
,IOC N
Dynamic Port
,Server 5068,Client 5064,PC
Access/PV List files question:
I am using the example files and for the access file the DEFAULT is where all requests go that aren’t listed as UAG or HAG?
ASG(DEFAULT) {
   RULE(1,READ)
For the Pvlist, the first 3 regex is this covering any PV name basically?  Does the next regex like Beam:.* then subset out from All to only Allowing the Beam 1 user to access these particular ones?
EVALUATION ORDER ALLOW, DENY
[0-9].*          ALLOW
[a-z].*          ALLOW
[A-Z].*          ALLOW
Beam:.*          ALLOW Beam 1
PS.*             ALLOW PowerSupply 1
gateway:.*Flag   ALLOW GatewayAdmin
test.*           DENY
ps\([0-9]\)      ALIAS PSCurrent\1.ai PowerSupply 1
Attachment: image001.emz
Description: image001.emz
PNG image
Attachment: image003.emz
Description: image003.emz
Attachment: image004.emz
Description: image004.emz
Attachment: image005.emz
Description: image005.emz
Attachment: image006.emz
Description: image006.emz
PNG image
PNG image
Attachment: image009.emz
Description: image009.emz
Attachment: image010.emz
Description: image010.emz
PNG image
PNG image
PNG image
PNG image
PNG image
Attachment: image016.emz
Description: image016.emz
RE: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup Manoussakis, Adamandios via Tech-talk
Prev: RE: CSS (Eclipse and Phoebus) super slow on a server with multiple users Jokinen Antti (F4E) via Tech-talk
Next: Re: MVME3100 boot failure at "Trying to find CSR on VME" Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: MVME3100 boot failure at "Trying to find CSR on VME" Pete Jemian via Tech-talk
Next: RE: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup Manoussakis, Adamandios via Tech-talk
