1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: MVME3100 boot failure at "Trying to find CSR on VME"
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Peter Linardakis <[email protected]>
Date: Mon, 29 Nov 2021 18:33:28 -0800
On 11/28/21 9:12 PM, Peter Linardakis via Tech-talk wrote:
> vmeTsi148 IRQ manager: looking for registers on VME...
> Trying to find CSR on VME...
> Does anyone have any ideas why a certain backplane will cause this?
CSR in this context refers to the CSR address space, which
is a VME64 extension using the geographic address pins,
which won't be present in an older VME32 crate.
Still, this error shouldn't be fatal as the TSI148 driver
should fall back and print "Trying to find CRG on VME...".
https://github.com/RTEMS/rtems/blob/e945e3fc4d6a6a74789c9a348120ec7d06e19231/bsps/powerpc/shared/vme/vmeTsi148.c#L1715
Also, the MVME3100 has a bank of DIP switches (S3) which
can override/replace usage of the geographic address pins.
Re: MVME3100 boot failure at "Trying to find CSR on VME" Johnson, Andrew N. via Tech-talk
MVME3100 boot failure at "Trying to find CSR on VME" Peter Linardakis via Tech-talk
Prev: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup Manoussakis, Adamandios via Tech-talk
Next: Re: MVME3100 boot failure at "Trying to find CSR on VME" Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: MVME3100 boot failure at "Trying to find CSR on VME" Heinz Junkes via Tech-talk
