1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: asynUSBTMC communications issue
From: "Dudley, David via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Dec 2021 21:24:33 +0000
Mark,
I’m trying to use the asynUSBTMC driver to connect to some SCPI USB devices.  I’ve got a Keithley 3390 Waveform generator, a B&K 9130B Power Supply and a B&K 8600B Electronic load all connected by USB.
All of the units work properly with the supplied LabView extensions on my Windows system.
Using the Asyn driver however, I can send most any query function that I want and get a proper response.  Send a command (even something like *RST or *CLR), and the device reports an invalid termination character on the Keithley, and the B&K’s just fail to answer or lock up.
I’ve tried CR LF, CR, LF, NL as terminations, and they all provide the same problems.
Any ideas on where to start looking?
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
Re: asynUSBTMC communications issue Eric Norum via Tech-talk
Prev: Re: CSS (Eclipse and Phoebus) super slow on a server with multiple users Michael Davidsaver via Tech-talk
Next: Re: asynUSBTMC communications issue Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: Dropdown menu problem when running Phoebus inside a Docker container Michael Davidsaver via Tech-talk
ANJ, 01 Dec 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
